![]() | Home > Puma (Tdci) > Nugget stuff intake and LR RAI - help |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 247 ![]() ![]() ![]() |
I have purchased a Nugget Stuff sealed air intake system but have an issue
I have a LR RAI and on trying to refit it to the nugget intake on the wing have just noticed the bottom clips of the LR RAI can now not clip over as the nugget intake is too shallow. What has others done - I can see no option but to cut the feet/clips off the LR intake (one i can leave 5mm the other will have to be cut off) and just sikaflex the intake to the wing, obviously it is still help in place by the upper two bolts Advise would be appreciated Ta |
Thanks for your reply, Landy still on the drive with no RAI re-attached, going to finish it off today and cut the tangs down so it clips over by about 7mm (cutting off about 10mm)
I will have to attack the nugget plastic with a dremel to provide sufficient depth to receive the clip, the front one I will need more trimmed than the rear as the clip lines up with a rib Once all done gona call up to Dia Walters Arena and have a play in the mud and water |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
dremel is one way, heating it up and letting them melt their own path also works very well. Cheers
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502 ![]() ![]() ![]() |
Ordered one of these yesterday .... sounds like another fun job 1951 80" S1 2.0
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2529 ![]() ![]() |
Got no snorkel on mine and been to walters a few times I wouldn't worry too much
![]() ![]() 2015 Discovery 4.5 Black pack Firenze red XS |
We are always out single vehicle so I am quite risk averse near extreme terrain or wading. Always 3 children with us too so not planning to get stranded if I can avoid it! 1951 80" S1 2.0
