![]() | Home > Off Topic > Tow ball projection beyond back axle. |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Hi, I need to get my head round the dynamic effects of the projection of the tow ball beyond the back axle as related to driveability of the combo. If for argument the car and trailer are identical each time and the rig rides level with a suitable nose weight and balanced load, as I understand it with a short distance from the axle to the ball the apparent vertical load on the axle is reduced because of the shorter lever action thus the front axle is not being unweighted as much and vice versa for a longer tow ball projection the rear experiences more load and the front gets lighter and stability is reduced. Correct? When applied to cornering the same longer lever action is equally unsettling on the car as the trailer tries to push on against the turning car. Obviously there's a lot of physics at play here but generally the shorter the rearwards projection of the tow ball the more stable the rig? Rhubarb and custard let fly with their secret weapon.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
I think that’s about right, certainly I think about in the same way
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
I think lambert's logic is correct. However, as we all know there is more to take into consideration for successful and safe towing. Making sure the trailer is level, making sure the nose weight is correct, loading the trailer correctly, making sure the load cannot move, adjusting tyre pressures of the towing vehicle. Defender 90XS SW
Towing livestock trailers as I do teaches the merits of having everything as perfect as possible because the sheep will move about even if only a bit they can't not. Hence wanting to make sure I have as neutral a combination as possible and if that means a new towbar with a significantly shorter rear projection then that is what it needs, my prime stock is too valuable to be taking unnecessary risks with. Rhubarb and custard let fly with their secret weapon.
