![]() | Home > Puma (Tdci) > Oil service light question + resetting after routine service |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Thanks, but I'm looking for the correct way to preemptively reset the service indicator when changing the oil- otherwise I'll have this same problem again if I don't reset the counter at point of service. 2014 Keswick Utility 2.2
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
My understanding was that if you follow the sequence shown in the post from dorsetsmith, then this resets the oil service counter back to the start point. So if you do this when changing the oil, this will be the same as the dealer resetting the oil service indicator.
That's what I did when I changed the oil in mine back in June. |
