![]() | Home > Maintenance & Modifications > Preparing for a full rebuild |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 519 ![]() ![]() ![]() |
Hi guys, looking to tap into the knowledge and experience of everyone who has done a full rebuild for some tips.
My current chassis is deteriorating quickly and will need a considerable amount of welding for its next MOT. I'd rather do the job properly and rebuild it onto a galvanised chassis this summer. I know the chassis will take a while to come so need to order that well in advance but is there anything else I should be getting sorted well ahead of time? Which chassis company do people recommend for quality and longevity (can of worms I know... ![]() What parts commonly need replacing so I can start looking to gather them now? Should I get my bulkhead galvanised? Are there any really good "whilst its off" upgrades to do (eg - dash replacements, axle/suspension upgrades etc)? Should I try to salvage my current wiring loom or scrap it and buy new? A lot of questions/wittering I know but any advice on the rebuild process will be greatly appreciated ![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
I will miss loads but there are many threads on rebuilds Greeni and myself for example have running threads.
I used Richards chassis and it was a great company to deal with, you can ask for bespoke modifications I believe. Loom will be look at and replace/keep once it’s removed as it depends if it’s been bodged or damaged. Storage is a big one as you remove parts have away of storing it and labeling it to make life easier upon reassembley. * Make a plan * most important make a plan and stick to it. Clean and inspect each item before putting it back together any doubts repair/replace as it saves time in the long run. Don’t half ar$e it, clean and paint axles etc a nice shinny rebuild can be let down by slapping on dirty/rusty parts like axles. Build up a collection of seals,screws,bolts and other fittings, trawl through the parts book and search the part numbers on google, often it will tell you what size bolt/screw/nut it is and you can bulk buy these much cheaper. Soundproofing and rustproofing even a galvanised chassis can rot out. I’ve missed loads but others will infill ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
When I did mine I swaped the tub and fitted a rear fuel tank, also used Richards Chassis
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I'd get a stainless bolt kit in stock
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Its a more personal thing but I would paint the chassis black as well
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Some great advice above. Id asbolutely galv everything you can. You only get to do this once! Save all your brackets and get it done in one go.
Id also try and save your existing bulkhead if possible. Buying one is expensive and it might not be exactly the same as yours for brackets and holes etc. You can easily make a rear loom to a better quality than original. I fed mine into convulted tubing and fed it over rather than inside the chassis so it can be modded in the future if required. Dont buy a specific defender stainless bolt kit. Go to your local supplier and buy an absolute load of m6,8,10 bolts in various sizes. The bigger or longer specialist bolts you can get in a kit, but you will use tons for just general fitting of ancilleries. You will have to decide whats good to replace whilst its in bits, but that list would be looongg ![]() In terms of chassis, id go with marsland every time. Ive seen plenty of richards chassis and they dont look to me as good a quality. The richards ones are apparently slightly thickers material, but marsland ones have much more webbing strenghtheners from what ive seen. The marsland ones are OEM from GKN who make them for LR. Marsland then change the engine brackets and galvanise the whole lot. You are getting a OEM chassis basically so no worries about things not being correctly made, which has happened with richards. do a google. I spent over a grand just with YRM metals who supplied a bunch of galv bits and replacement bits for the tub and other bracketry. I found the front edge of the tub was rotten, plus the rear edge, and I changed to galv cappings. You wont know until you pull it to bits. Dont know what tools you have, but I bought an engine lift which has been really useful for all kinds of things. e.g. its lifting the rear of my tub right now while i fix it ![]() If you want to really save money, you can lift the entire body off inc the bulkhead one go, and drop it down onto a new rolling chassis. I was going to do this, but decided to go balls deep as it were lol. enjoy! and make a thread of your antics. |
Thanks for the advice everyone! There will definitely be a thread!
![]() Pretty sure it would drop to pieces if I tried to do a full "body off in one job" as the seat boxes are pretty rotten as are the tub cappings. I think I'll certainly end up spending a fortune with YRM as like you say I'd rather do it all properly now. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
id definately recommend doing the tub capping. it looks awesome once its done and isnt very difficult.
Tommybahama32 Member Since: 11 Sep 2017 Location: cheshire Posts: 31 ![]() ![]() ![]() |
I replaced my chassis about 4 years ago, used a Marslands chassis and would recommend them totally, everything fitted perfectly no redrilling or tapping holes very good finish and fit. As has been said these are genuine GKN chassis. Collected mine from Marslands, really helpful showed me the different engine mount options. Top job.
