Home > Technical > Headlights
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
Headlights
I got in the landrover to leave work tonight flicked the sidelights on grand, then the the headlights - dipped Beam and nothing it’s not the main small light switch as I have tried a new one and still no light, all the other lights work apart from dipped Beam, main doesn’t work when the stork is pushed forward but when you go to flash they work, if I pull the flash stork to me just a little I get dipped Beam, then if I give it a bit more main Beam comes on. Am I right on thinking that I need a new indicator/main Beam/ horn switch? I’ve riggled the connectors on the back of the headlights but it wasn’t that. Forgot to say it’s a 2011 110, Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #672098 19th Dec 2017 8:58pm
grafty99
Sounds like the pink (headlight) relay behind the dash has failed. same happened to mine except when switching from main to dipped beam which was interesting Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #672104 19th Dec 2017 9:16pm
grafty99
It is possible to bridge the terminals with wire and a couple of spade terminals as a get you home fix Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672105 19th Dec 2017 9:17pm
Harryb450
Which terminals do I have to bridge? Where abouts is the pink relay behind the dash?Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #672108 19th Dec 2017 9:28pm
grafty99
I'm not sure on a puma, there is an image somewhere I've seen. I'll see if I can find it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672109 19th Dec 2017 9:29pm
grafty99
Stolen from a previous thread on here. It is the dim dip relay but it does affect the normal headlights Thumbs Up
1990 Vogue SE
Post #672111 19th Dec 2017 9:32pm
Harryb450
Where abouts are these on a 2011 puma, I can’t find mine behind the dash. Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #672120 19th Dec 2017 9:59pm
grafty99
I'd have thought behind one of the flaps either drivers or passengers footwell. But I'm not sure as I never looked when I had a puma 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672121 19th Dec 2017 10:02pm
ickle
I don't think there is either a dim dip relay or a headlight relay on a puma, hence the column switches fail.
New column dip/main indicator switch and one of the advertised headlamp loom upgrades probably required.
HTH
Keith
Post #672123 19th Dec 2017 10:14pm
grafty99
Some puma's definately have dim dip Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672125 19th Dec 2017 10:18pm
Harryb450
Problem solved 😁 my suspicions were correct, it’s the flash/ indicator/ horn switch the plastic has melted and is keeping the contacts apart, bent the contacts slightly to get me back on the road while I get a new switch. And yes just to clarify I did find the relay that’s in question and tested it but all was well, it’s in the fuse box under the dash. thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #672133 19th Dec 2017 10:32pm
grafty99
Nice one Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672135 19th Dec 2017 10:40pm
Symptoms are conclusive that it's the dip/main/flash stalk switch.
Pumas without headlight level adjusters (ie all the early N1 type approved vehicles) had the abhorrent dim dip feature, the relay is in the fuse/relay panel above the driver's feet and the resitor is under the osf wing.
Post #672148 19th Dec 2017 11:44pm
zsd-puma
Keith
Non-Dim dip ones also have the relay, however all it does is cuts the power to the headlights when you turn the ignition off.
Whether you have Dim-dip or not the full power still goes through the column switch.
Just think, when we leave the EU the UK Department for transport will be free to reintroduce crap features like that. Originally the DfT wanted all cars in the UK to have dim-dip, the EU overruled them as it would have introduced disparity between europe wide type approvals, hence you don't find it on any cars built outside of the UK.
Post #672154 20th Dec 2017 12:18am
Harryb450
Just for future reference, does anyone know what the other 6 relays are for in the dash fuse box? I have a diagram for the ones under the drivers seat. Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #672224 20th Dec 2017 2:16pm
