Home > Td5 > LT230 Transfer box question
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I'm about to fit a Disco transfer box to my Defender and have a question. The power take off point has a cover that is bolted on had a squirt of mastic (RTV) around the mating faces to keep the oil in. The unit that this bolts to (bearing/shaft housing) that has the bearing face for the input gear has no sealant, it looks just a "good" machined finish. Is there a need to try and RTV this part to the box or has someone been in here and not refitted gaskets? Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #671885 18th Dec 2017 9:22pm
I would suggest a very thin bead of sealant, as that plate holds the bearing in place, and if it's too thick it'll affect the free play in said bearing.
Post #672380 20th Dec 2017 9:58pm
Prior to transfer box serial number 288709E there should be a gasket fitted, from this serial number use Hylosil 2000 for bearing housing.
For the cover plate use Hylosil RTV 102 on all.
Post #672409 21st Dec 2017 12:05am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
^^^^Yup what he said...^^^^. Just torque it correctly.
Good luck! 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #672541 21st Dec 2017 8:40pm
