Home > Technical > Two Stroke in Diesel problems
Page 2 of 2 <12
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Yeh, Greeni is wrong!
The puma trumps the td5 any day.... Rolling with laughter 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #671649 18th Dec 2017 8:13am
Procta
ian series 1 wrote:
Have to agree!
what is the point in petrol company's refining quality diesel, car manufacturers developing precision Diesel engines,
If your going to whack a load of two stroke oil through it?
Quote....
The results of a study that the practice of dosing diesel with 2-stroke oil is surprisingly ineffective in terms of lubricity and cetane improvements. Engine performance, fuel consumption and emissions were also unchanged, however the use of 2-stroke oil in diesel is potentially harmful to modern diesel injection equipment. Trace amounts of zinc, an element which is found in most 2-stroke oils, are well known to cause injector nozzle fouling and the study measured high levels of injector fouling when the test engine was running on diesel dosed with 2-stroke oil. While the oil industry may not mind the additional revenue from the sale of 2-stroke oil with each tank of diesel, this study demonstrated that it is not in the best interest of the user to do so.
I know there will always be a debate about this, and many on here swear by it,
Personally I wouldn't bother... Wink
the 306 Hdi lads had this debate too, about adding 2 stroke using the common rail injection system. One lad did put a bottle of 2 stroke to a full tank, and all it did was make the injectors quieter. No other problems at all, Smile
I do agree with you I wouldn't bother at all, in fact I wouldn't bother with additives either. I added redx stuff to my Dturbo 306 ( mechanical pump) and it did the square root of Censored all. I decided to stop filling up with asdas Censored fuel and guess what, The car was less smokey and more happy! my dad did the same thing with the 406 ( he had the same engine) and he ended up saving £40 a month! He wasn't using as much at all. So we have now been filling our cars up with either shell or BP. So I recon it all boils down to quality of the fuel, some times I do wonder how well maintained supermarket petrol stations are. I know the supermarket I used to work at never even bothered at all. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #671748 18th Dec 2017 5:31pm
Procta
you are both wrong! The TDI trumps the TD5 and puma any day, and you can bank that at Lloyds Mr. Green Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #671749 18th Dec 2017 5:32pm
zsd-puma
It's not really the filling station that's the issue. It's the additive package which gets added to the base fuel when it's loaded into the tanker which makes the difference. The branded fuels tend to have better additive packages than the supermarkets. The aftermarket additives do the same to an extent, but they're not scientifically blended and matched like the oil companies do themselves.
Post #671815 18th Dec 2017 8:08pm
Not all fuel stations, premium or otherwise have super diesel.
Constantly switching brands is not going to make a difference if anything worse because your mixing all sorts of additives and mixtures all be it tiny difference between them all.
For these reasons, I stick to Esso standard. (Or occasionally Shell standard but very rarely) and Millers addictive.
Premium brand fuel of the same brand all the time, with the same additive.
Then there, will be very little motor re-calibration having to be done and you can keep running at good performance.
It's not always practical to stick to the same brand, but this is what I tend to do. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #671820 18th Dec 2017 8:25pm
Alex1976
I wasn’t really looking to restart the debate about 2 stroke, just reporting that my use of 2 stroke seemed to be the cause of a starting problem, or a major coincidence if not. I guess I could start putting 2 stroke back in and see if this then sees the return of the starting problem. There can only be so much coincidence before it becomes test results that are fact and point to the cause.
Post #671900 18th Dec 2017 10:44pm
roel
You don't mentione the model you are driving but slow starting on my td5 was the grease in the startermotor gearbox. After 14 years it was some starnge sticky Censored . like if I poked with a screwdriver in a tarmac raod on a hot summer day. I really had difficulties cleaning it even using brake cleaner.
Now with new multi purpose grease it start better then ever. Roel
2003 90 Td5 (2009-now)
Post #671979 19th Dec 2017 12:37pm
donmacn
Not challenging you Steve, I just wonder how much of a difference it really makes, and how much is folk actually expecting a difference - a placebo effect if you like?
Maybe that's a difference between a Tdi and TD5? My brother invested in the kit to make 'diesel' from used vegetable oil, filtering, additives etc. I don't know all the details. Every now and again I've stuck some into my old wagon. I can't say I've ever noticed any difference to performance, or smokiness or whatever. So, if my car runs happily on that stuff, made up in the back of his garage, does this or that additive pack in the fuel really make any difference?
THe comment above about saving money using supermarket vs Oil Co. branded fuel was interesting - and something that could be loosely monitored by anyone keeping receipts, recording mileage and then doing the average MPG calculation. That could be something interesting to play with. Not so easy where I live - real 'Tesco Town'. Of the 8 petrol stations, only three are oil companies, then it's Asda x 1, Morrisons x1 and Tesco x 3 Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #671986 19th Dec 2017 1:02pm
jst
I can't see its linked to poor starting in this case. Coincidence. See how she starts when it gets colder again. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #672056 19th Dec 2017 6:34pm
jst
Assuming she had been filled recently that is and not running on summer fuel? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #672057 19th Dec 2017 6:35pm
Alex1976
I am going through about a tank a week so it should be winter fuel. The odd thing is that the starting has been poor since the warm weather back in summer and the cold weather made no difference better or worse.
The only change was when I stopped using 2 stroke and filled three tanks of V Power, ironically as we were getting the we were getting into the very cold weather, and this is when magically the starting really improved - not instantly but over the last couple of weeks.
Yes it could just be a coincidence but the symptoms point to the 2 Stroke so far. If I put 2 stroke back in and the problem starts again then that is more than a coincidence for me.
I don't want to restart using 2 stroke at the moment as I need to know it will start with no drama.
By the way - I am not anti 2 stroke - I have really liked using it as I think the engine does run smoother but I can't use it at the cost of having poor starting. I am using V Power as I feel that has a similar effect to smoothness of the 2 stroke.
Post #672113 19th Dec 2017 9:39pm
Page 2 of 2 <12
