Home > Puma (Tdci) > Best replacement TDCi clutch
Page 2 of 2 <12
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
ickle wrote:
I had the Clutchfix unit fitted last week - Ben told me that the slave is a 'one trick pony' single use and must be replaced when the clutch is replaced.
All ordered from him and feels really nice in use.
After two failed Borg and Beck clutches - one lasted 300 miles, the next about 5k I'm hoping this one will work!
Keith
I put a new OEM clutch in mine not long after I bought it and so far seems to be going well, but I was nosing on eBay and spotted a clutch fix unit and thought I’ll keep an eye on that for when mine starts rattling! Anyway I ended up winning it, thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #671594 17th Dec 2017 11:05pm
Harryb450
I have spoken to Clutchfix today and they have confirmed that it does use the standard OEM slave cylinder, so basically you just swop the friction plate and the cover. The bloke told me that the ceramic paddle clutch same as the one I have is for Bowler landrovers and racing applications and they stopped making them in November last year. How are these ceramic paddle clutches compared to the OEM type one? Are they aggressive? I know some of the folk on here have the ceramic type fitted so I would like your opinions on them please, thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #671736 18th Dec 2017 5:01pm
Pickles
Did I not read on this forum some time ago that the latest O.E. Defender clutch is uprated?....same as the one in the Autobiography?
Pickles.
Post #671872 18th Dec 2017 10:08pm
Harryb450
Please don’t be shy!!! NO ROAD..........EXCEPT FOR LANDROVER
Post #672273 20th Dec 2017 5:30pm
leeds
Ceramic clutches are NOT,REPEAT NOT, suitable for standard road going vehicles.
Ceramic clutches are a ON/OFF clutch, no chance of slipping the clutch or gently finding the biting point.
Now
Quote:
Ceramic Clutches – Exedy Racing and Sports Clutches
Ceramic clutches can absorb more heat than organic ones, thus making them better suited to high performance applications. You will find that the price of a ceramic clutch is reflected in fact that they specifically for high performance driving.
Ceramic clutches will wear much faster if you ride the clutch, and can experience some shudder or chatter on engagement.
Keeping in mind also, that a ceramic clutch is quite savage on both its meeting components, the flywheel & pressure plate.
Exedy Ceramic Clutches come in a range of racing and sports clutches:
taken from http://www.clutch-kits-australia.com/organic-clutches.html
If you have a highly modified, high performance Bowler with 500 HP and do off road racing then a ceramic clutch would be suitable.
For an explanation of different clutch materials have a read HERE
4x4overlander are stocking the Clutchfix clutches.
HTH
Brendan
Post #672802 23rd Dec 2017 12:21pm
Harryb450
Thankyou Brendan, I won’t bother fitting it then. Might offer it for sale on here, as it’s no use to me! Thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
Post #672861 23rd Dec 2017 6:22pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Re: Best replacement TDCi clutch
PAT303 wrote:
Well I'm on my third clutch at 170,000km's in my TDCi defender.Is there a good quality replacement clutch that has been found to last,or is at least better than the OEM clutch?. Thanks.
I know you don't want to hear that, but may it be related to the way you drive the car? If so, replace your driving moods may cure the pain. If you think eating clutches is normal, please report the way you are driving, so we can get a more helpful answer (Btw, I am at 200+k on my first clutch, first lining with 70% offroad and frequent towing usage, so think of 170k on a third of being a bit odd, sorry for that). Never forget: cars have owner, Landrover have field service personnel.
Post #672969 24th Dec 2017 8:23am
ickle
Ninety, If you're on that mileage with a tdci clutch you are probably the exception rather than the rule.
A good proportion of the tdci clutches fitted to Land Rovers and their cousins in Mondeos and the like with solid flywheels have springs made from cheese or recycled loo roll centres depending on manufacturer and no matter how its driven will fail.
Likewise the adapter shaft between gearbox and transfer box can fail at low mileage for no reason, I replaced mine at the first clutch change (around 100k) but it had very little wear at all, others in low mileage in never-abused dry weekend only shiny motors have given up in 10k.
Its the springs that are failing, not the linings from slipping the clutch like a granny!
Post #673080 24th Dec 2017 4:42pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Anecdotal but first hand at least.. my TD4 had clutch spring failure at 30k. I was gentle as I could be with the drive line too, still had barely any meat left on the adaptor shaft splines. No towing, light Offroad.
From now on I’d always recommend doing the job before anything fails just for peace of mind. Clutch springs could cause damage if they fell out and the splines will lease you stranded.
Post #673102 24th Dec 2017 5:50pm
dgardel
Italy
Me and many of my italian colleague are using the Transit 4x4 clutch, very strong! not more problem!
Sachs (3182 600 157)
A big improvement... look at the pics
vs LR
Clutch disk and spring plate are much much stronger.
I run 80.000km with his clutch, it is the DEFINITIVE SOLUTION!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #673340 25th Dec 2017 5:05pm
dgardel
Italy
Slave:
- LR068979 Piston
- LR068981 coupler
- LR068982 limit valveO
- LR004390 bearing
from Ford transit 4x4 clutch KIT:
- OE-7C11-7540-BB BUT MUST BE SACHS 3000 950 727 CLUTCH KIT (Disc + spring plate)
or buy it here: https://www.bestpartstore.co.uk/7428173-sachs-clutch-kit Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #673347 25th Dec 2017 5:34pm
InternationalDBA
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I fitted a National clutch to mine at 119,000 miles. Still going well at 133,000 miles.
Post #687688 19th Feb 2018 9:24pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Just wondering. Has anyone tried both? The sachs and the clutch fix I mean.
And is there a winner? The clutch fix is a bit more expensive and i'am wondering if it is worth the extra money.
Kind regards Jacco a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #687988 21st Feb 2018 12:07pm
JOW240725
There are Syncro Clutches as well now! I can't compare with others but another option that seems to get good reviews. James
Instagram @suffolk_rovers
Post #687992 21st Feb 2018 12:21pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I had one for years on a track day car which I also used on public roads. Didn't have a single problem finding the biting point. No issues crawling in a traffic jam or parking the car in a tight spot.
Although you have to be a bit more careful, I don't agree on they are 'on/off'...
Post #688003 21st Feb 2018 12:58pm
Page 2 of 2 <12
