![]() | Home > Technical > Leaking sides to rear tub sealing advice |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I would be inclined to put more bolts in
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Having said that I put new seals in mine when I rebuilt after the respray. They're really thick (40mm or so) 2002 90 Td5 Station Wagon
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
It has the correct bolts and brackets George. Additional ones would have to be drilled, not the easiest and permanent holes
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
I would unbolt it, replace the seal, and then check for rust/other issues. the standard seal is good except for the one spot by the seam of the cappings. you can add a bit of sealant, but something is cleary wrong fundementally if it's leaking.
It's an hour's work and parts are cheap. V8 90...WIP |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Masking tape, upper and lower part of gap, apply silicone liberally in one big line with BARREL gun (skeleton guns are a waste of money and effort) lick finger and smooth it in in one big line. Peel masking tape off. QRZ 2e0vpf
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Sikaflex mastic is a great product we use it a lot at work, it’s easy to finish (like bathroom sealant) but does stick like
![]() ![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
Here was my result.
![]() Click image to enlarge QRZ 2e0vpf |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
Jim, I had a leak under the rear quarter light (near side) and I thought it was the tub seal, put some dum dum around the inside of the light, no more leaks, worth a try
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Greeni has made a very neat job, But I would put new a seal in as mastic is quite severe
Knew I'd seen it somewhere ![]() Thanks Greeni. Trade tip - Better than licking your finger, use a spray mister, with some water and a few drops of washing up liquid ![]() |
My fingers usually are sticky from sticky buns. I appreciate the tip though
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1771 ![]() ![]() |
I do the same as greeni but use a polymer sealant instead of silicone. I also do the front bulkhead.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Plenty of different brands of proper car body sealer available for the job.
Silicone is a nightmare if you ever have to have any paintwork done. |
Quick update,
Rear tub sorted, new seal sorted that. Now found another leak ![]() Drivers side roof to windscreen , leaking in the corner where the dum dum has deteriorated and disappeared, dug it out and cleaned up and resealed with sika ......... fingers crossed |
