Home > Td5 > Should I Add Anti Roll Bars
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Have a 90 HT TD5, with new fitted Bilstein Dampers and Sport Springs (2″ Lower)
However from reading on here and in reality, she was never fitted with anti roll bars, front or rear
The new suspension is brilliant and stops her feeling like a boat, but is it worth fitting ARBs?
The drive is 100% better, but am I wasting money or is adding OEM ARBs worth it?
Post #671201 16th Dec 2017 12:11pm
grafty99
Anti roll bars are a must for road biased defenders in my opinion Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #671210 16th Dec 2017 12:56pm
barbel jim
Yes well worth it Mr. Green The front makes the most difference. Genuine front and rears on my old puma and the TD5
Post #671212 16th Dec 2017 12:59pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I'm going to give them a go since my 90 isn't going to see any pay to play or hardcore laning, can anyone comment (from experience not reading things in magazines/internet) how they change the way a defender handles?
I like the defender handling and i'm worried it might make it more likely to understeer? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #671214 16th Dec 2017 1:13pm
barbel jim
Really you only loose a bit of articulation, but can gain a go cart Mr. Green standard anti roll bars will stop a good 60%. Of the body roll. An updated rear would be more noticeable on a 110 due to the rear overhang. Coupled with updated shocks makes everything tight,direct and responsive. It basically sits flats, The difference is massive. The only downside with the shocks though is it can make it a hard ride. I prefer it as the 90 is so predictable. In the snow it was a lot of fun Mr. Green
Post #671223 16th Dec 2017 3:19pm
grafty99
The most difference in my opinion is the way it transforms transitional cornering loads, when negotiating a series of left - right- left type bends.
Before - you had to wait for the suspension to 'settle' when coming out of one bend before turning into the next. This obviously means reducing your cornering speed to allow for this transition. Failure to do this causes quite severe oscillation of the suspension (read lock to lock tank slapper Shocked )
Anti roll bars (especially updated ones) reduce this massively allowing you to change direction with much more speed and confidence. This is most noticeable when going straight on at a roundabout for example.
Another advantage to anti roll bars it that they reduce understeer by increasing the load on the inside tyre.
All in all a very worthwhile modification which (unless going extreme) won't effect off road performance and is nothing but a benefit on road. I can't see why you wouldn't do it to be honest Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671230 16th Dec 2017 3:59pm
barbel jim
George gives a grown up elequant reply, and I sound like a boy racer Rolling with laughter
Post #671250 16th Dec 2017 5:34pm
grafty99
Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671253 16th Dec 2017 5:40pm
grafty99
Nothing like a bit of role reversal Shocked Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671255 16th Dec 2017 5:42pm
DieselBeast
1998 Defender 90 300 Tdi PU Java Black
I thought they were all fitted with front anti-roll bars. The body roll is bad enough with them fitted Shocked
Post #671260 16th Dec 2017 5:59pm
grafty99
Basically if it came out of the factory with boost alloys then it had anti roll bars Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671263 16th Dec 2017 6:11pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
My 110 had an ARB on the front from the factory
Fitted an Alive rear ARB, and the difference in handling was immense Bow down
Post #671266 16th Dec 2017 6:34pm
Pickles
Re: Should I Add Anti Roll Bars
With the springs & dampers you have fitted, I would say that ARBs would be a very worthwhile addition,..they will definitely improve handling in all sorts of conditions that you will encounter on the ROAD. As many have said, they will restrict articulation off road, but if you're road orientated, then you should fit 'em.
Pickles.
Post #671293 16th Dec 2017 8:46pm
True for 90s I think, but not 110s. My DC had Boosts from the factory but only gained ARBs a few years ago when I retrofitted them. I think if you had 1 tonne or HD suspension you didn't get ARBs, but I stand to be corrected.
They make a massive difference to the road manners especially if (like me) you have a Patriot rack which you load to capacity. The difference off road is only noticeable under extreme conditions and is a small price to pay.
Post #671315 16th Dec 2017 9:55pm
mk1collector
Same here, my 110 had boosts but no arb's. Made a big difference when fitted though Thumbs Up Ray
My build thread
Post #671323 16th Dec 2017 10:07pm
