Home > Puma (Tdci) > Front window dropped
mick
I see there is a thread on rear windows dropping but this is completely different I was coming home to night and the NSF window just dropped down into the door Shocked
I pressed the window button nothing motor made a noise but window stayed down,got home frozen Evil or Very Mad took the door to bits to find the bolts that fix the window mechanics to the bottom of the window had come out so just be warned if your door card off check the bolts Thumbs Up
Post #67051 12th Apr 2011 8:36pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Nice one Mick, put some stud lock on them Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #67052 12th Apr 2011 8:38pm
Eduardo
Well It's a Land Rover
This thing happens to me at the beginning (Only 2,000 km old) at the vacations, so I dismantle the door with the help of the dealer at the other side of the phone and found the same problem that you.
In my case the bolt were loosen from factory. Check also the other window...
Cheers Eduardo
Post #67054 12th Apr 2011 8:43pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Same happend to my last puma, was in the Alps at the time.
Post #67056 12th Apr 2011 8:45pm
mick
Will check the other side sometime thing is the door cards are so s**t and i have had them off once when the door handles came loose as well Shocked
Post #67057 12th Apr 2011 8:47pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
My front left did the same a while back, easy fix as has been said, door card off and put bolts back in Shocked . Another one for the build quality stats Thumbs Up Oh well still love it to bits. Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #67089 13th Apr 2011 7:37am
Lorryman100
There was a SSM for this issue, SSM39031 referred to the bolts coming loose and the use of loctite to rectify. Thumbs Up
Post #67096 13th Apr 2011 8:44am
