![]() | Home > Maintenance & Modifications > Diesel cabin heaters |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Have a look at the Planar heater on 4x4overlander/Nakatanenga website.
Brendan |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
A post from a few days ago.
http://www.defender2.net/forum/topic58275.html |
| Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 590
Hello,
I have put mine inside my mss cubby box, holes drilled below for exhaust and burner inlet. A hole at the rest for hot air out which goes into a manifold to distribute the hot air. I posted some pictures here a while ago. http://www.defender2.net/forum/topic45695.html ![]() |
| steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 193
Fitted mine in passenger seat box so exhaust and intake go through the floor and hot air is pumped out high up in passenger footwell via a directional nozzle.
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1697
rear wheel arch behind passenger seat.you have a limited length of fuel pipe that the std pump will pull from.
nothing wrong with planar heaters but almost every truck, bus or van that using diesel power heating uses eberspachers or webasto.lots of dealers easy spare parts. |
| All times are GMT |
