![]() | Home > Technical > Wiper speed issue |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
The very fast speed on the Puma wipers doesn't work. Intermittant and normal speed are fine. Any ideas? 1982 88" 2.25 diesel
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
If all other speeds work normally then chances are it's the column switch. Do they just stop? Or do they not increase in speed? 2002 90 Td5 Station Wagon
When the stalk is moved up from normal speed to very fast, the wipers just stop. Sometimes it is possible to get them to move but they only drag across the windscreen very very slowly. 1982 88" 2.25 diesel
In that case it could be that the second motor winding has failed, only way to know for sure is to test the wiring at the motor end and check voltages
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Wiper relay unit...check the connections, WD40 etc Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Having said that, as the column switch is easiest to remove, you could test that first before getting access to the motor
Wiper relay is another possibility
Thanks to you all for the replies. All of the above had crossed my mind but I wondered if anyone had had the same issue and had a definitive fix
![]() ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Just so you know, the park switch only does that, parks the wipers when you switch them off. To save the agro I wouldn't change it unless it has failed
O.K. I'll leave the park switch be. Where is the relay unit and what needs checking? I've lashed on the WD40 on the outside of the spindles. I'll ad some more over the next day or so. Don't use the very fast speed as a rule and just found out it wasn't working correctly by chance. I just need to make sure it is working for when the vehicle goes to the test centre next year. 1982 88" 2.25 diesel
I'm not sure where the relay is on a puma. My guess is under one of the dash flaps. All you can test really is that it is secure. Have you another defender to swap wiper relays with? 2002 90 Td5 Station Wagon
My wipers on my last Puma went bonkers, going slow, then fast, intermittent all over the place & refusing to park...changed the wiper relay & all was good, it had got wet inside & the spades were corroded. When I removed it the wipers worked perfectly on fast, slow, but wouldn't park suggesting that the relay overrides the normal wiper function.
The bit in question: https://www.ebay.co.uk/itm/AMR2341-Land-Ro....l4275.c10 My 300TDi Wolf also had the exact same problem with water in the actual relay housing, no need to change the part as sandpaper & WD40 fixed it. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
Have a look at this old thread...
http://www.defender2.net/forum/topic2031.html Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
