![]() | Home > Maintenance & Modifications > The Syncro Gearboxes’ Slickshift |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
Anyone fitted one , does it make much of a difference?
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Have a look in the search bar for numerous posts on these
![]() 2008 SVX 90 2000 XS TD5 90 |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
I hear an echo ...just asked that question recently!
![]() I guess its a mostly yes it improves the gearchange ...with a few folk saying its rubbish,,so im still in a quandry as £200 could be spent on something else on the money black hole that is the defender.... if the haters could firm up why its rubbish it might help my decision as i have no problem with the gearchange but swinbo hates it with a passion. |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
/\ This.
I am in exactly the same place! |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 521 ![]() ![]() ![]() |
Maybe the effect is different on different types of boxes?
I fitted one to my LT77 box and it made a huge improvement. I drove another 90 with an LT77 and no slickshift the other week and it reminded what a good mod it is. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Thanks, I tried one at the GBLS last weekend but only on the stand , seemed a good idea .
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Also don't forget that it depends very much on the condition of the gearbox in the first place. Had one now for the last 15k miles on a gearbox that has done 147k miles and it does exactly what it is supposed to do ie remove the length of throw/sloppiness of the gear stick between changing gears. Beforehand the stick was all over the place, but then made sure I did the LR recommended modification before I fitted the slick shift. Had I not have done that first then I probably wouldn't have had the benefit of what the slick shift is designed to do.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964 ![]() ![]() |
Which Mod is that then the stop screws
It was the one with the spacers.
http://www.defender2.net/forum/topic24561....earbox+mod |
