Home > Technical > Handbrake light flickering - what does this mean iffy switch
Stacey007
Hello
My handbrake light is flickering every now and again...
Any ideas...
Post #668070 30th Nov 2017 10:15pm
grafty99
Also warns of low brake fluid. Worth checking Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #668071 30th Nov 2017 10:16pm
Stacey007
Thumbs Up thanks
Post #668073 30th Nov 2017 10:20pm
Brake fluid level 👍🏻 _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #668080 30th Nov 2017 10:33pm
jst
Could be earth on the switch or low brake fluid, it more evident when going downhill then it's low brake fluid Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #668161 1st Dec 2017 8:39am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
the light is triggered by two circuits;
1) Brake fluid low level warning
2) hand brake - this case a wire which can rub on handbrake fulcrum point - it can intermittently contact ground and put the light on.
I've had both situations on mine ! My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #668171 1st Dec 2017 9:35am
Generally if it is a low brake fluid warning you can make the light come on if you brake whilst going down a hill.
I find that I need to keep the fluid level in the reservoir slightly above the MAX mark: if filled to the MAX I get the flickery light effect.
Post #668180 1st Dec 2017 10:06am
Snorkers
Scotland 2007 Defender 110 Puma 2.4 HT Keswick Green
It might not be the same issue, however my Puma used to have an intermittent hand brake warning lamp.
After checking and confirming the fluid level was fine, I examined the handbrake switch. It's a simple affair exposed by slipping forward the handbrake boot. I think there were one or two plastic fasteners to be removed. Easily done and they can be refitted easily.
On my swtch, the end of the plastic plunger had become damaged/unevenly worn. As a result, when the handbrake was released, the plunger didn't always move forward allowing the lamp circuit to open. After easing and lightly reprofilling the end of the plunger all now works correctly, and has since fixed nearly two years ago.
The switch is really basic in operation and I can't imagine it would be dear to purchase if you wished to replace it. But really its almost to simple to be beyond easy repair
Hope this might help.
Regards and best wishes for the festive season.
Snorkers
Post #668618 3rd Dec 2017 2:26pm
grafty99
The switch is around £15. Silly really for something so simple! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668621 3rd Dec 2017 2:36pm
I've had the light come on, in cold weather, the rubber gaiter around the handbrake lever itself becomes hard and stiff Shocked and doesn't let the lever fall back to its "stop" position, thus making the light come on.
Post #668731 3rd Dec 2017 9:01pm
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
I had the same trouble a few weeks back, it turned out to be the little float thing in the fluid reservoir had stuck, gave it a few light taps and the problem was solved NO ROAD..........EXCEPT FOR LANDROVER
Post #668771 3rd Dec 2017 9:59pm
mick
Probably need new pads Thumbs Up
Post #669040 4th Dec 2017 11:37pm
grafty99
Haven't had a reply to the thread, perhaps there was a fault Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #669043 4th Dec 2017 11:51pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
As mick said, probably needs new brake pads. Mine does it as a handy early warning system if I haven't already caught it. North Cumbria Search and Rescue - Team Leader
Post #669045 4th Dec 2017 11:51pm
Procta
I had this trouble last night, Checked the juice in the reservoir and topped it right above the mark as you said. Thumbs Up
So looks like it could be a very early warning system Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #686774 15th Feb 2018 3:06pm
