Home > Technical > How do I successfully program in a new plip (fob)????
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Need some help as I am trying to program a new plip in to a 10MY Defender.
I'm using a Faultmate Extreme MSV-2 and VE 1.29
This is what I have done:
Select Plip Learn>Start
Get screen on laptop saying what to do
Press new Plip button until hazards flash at which point alarm horn also sounds once.
Click on Continue.
Select Plip Learn>Finish
I then tested the new plip and it works Smile Then I tested the other existing plip and it no longer works Sad
Repeat process with existing plip and now it works and the new one doesn't - WTF Confused
What am I doing wrong or is this a 10AS issue?
Am I correct in assuming I should be able to press one plip's button until the hazards flash then repeat with the next plip and once done click finish? If so this doesn't work with this vehicle.
Has anyone done this with a Faultmate? 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #66794 10th Apr 2011 7:42am
Grockle
aye up Dererk,long time no see,how are ya mate ?,we got our remote done at the dealer,not much help as your nearest is 1,100 kms away Confused 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #66795 10th Apr 2011 8:07am
dm_td5
aye Rog, not to bad but had a few issues.
The vehicle is a 4 month old Puma that was supplied with only one set of keys. The dealer - amongst a raft of other issues - lost the second set Rolling Eyes So they had to provide a new fob and key. It's a friend in towns Defender and I have the Faultmate on loan. Will probably buy one myself soon. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #66800 10th Apr 2011 9:39am
astoltz
South Africa
Re: How do I successfully program in a new plip (fob)????
Click on Continue.
Yes Done this several times using a Faultmate MSV-1.
I Click on Continue then I press the First remotes button until the alarm horn sounds then the Second until the alarm horn sounds, then Finish
Abrie 1997 Land Rover Defender 110 HT 2.8i
(BMW M52)
2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
Post #67138 13th Apr 2011 1:33pm
dm_td5
Thanks. I'll give it a go and hopefully get it right this time. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #67210 13th Apr 2011 8:43pm
