Home > Td5 > Removing rear drive shafts
excossack
To remove the rear drive shafts on a 110;
Slacken off wheel nuts, jack up and support axle.
Remove wheel & centre rubber cap (if fitted)
Undo drive flange bolts
Withdraw the shaft?
Refitting - being the reverse of the above?
Seems quite simple....What about bearings and oil seals? Will the shaft withdraw without the need to remove wheel bearings & seal ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #667875 30th Nov 2017 9:48am
rallysteve
I presume you have alloy wheels? if you have steel wheels you dont even have to remove.
No bearings or seals to worry about. There is a gasket on the drive flange but cleaning up the faces and using a decent silicone will be fine for reassembly.
Leave the drive flange on the halfshaft for removal too.
Post #667876 30th Nov 2017 9:53am
excossack
Cheers Steve.
Yep I have alloy wheels. Seems quite simple TBH. 1999 Defender TD5 110
Regards
John M0VAZ
Post #667883 30th Nov 2017 10:29am
rallysteve
Yeah, just go easy with the drive flange bolt removal as they can be known to snap if they have previously been overtightened/threads full of silicone.
Its worth having a bit of rag to hold around the shaft as you pull it out as it will likely be coated in axle oil.
I generally like to drain the diff oil before removing the shafts as i can overflow through the end of the stub axle if it is too full or you are parked on a side slope.
Post #667888 30th Nov 2017 11:09am
