![]() | Home > Puma (Tdci) > Biggest Tyres on standard suspension |
| Genis Member Since: 25 Jan 2009 Location: Windhoek Posts: 17
What is the biggest tyres that can be fitted on standard suspension without rubbing. Would 255/85R16 mud tyres fit or would it rub with full articulation?
Thanks, fekete.
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
285 BFG MT`s fit. But sometimes rub the radius arms depending on axle articulation
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
285's seem ok on mine as well but I do have 8.5inch wheels which are off set.
| Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824
I have 255/85 on disco steel rims with standard land rover springs. Have yet to notice any rubbing. The springs are fairly new.
The off set of the wheel rims would also effect this , what wheels you planning to use ? N. |
| Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67
255/85 will tear off small parts of ur 'mudguards' i dont know how to call it in english u know it prevents spraying of dirt from ur tires :p on full articulation, did it on mine but not anything major just little bit nibbling
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
"Mudguards" is exactly the right term in English. |
