Home > In Car Electronics > After market rear-view camera kit for new 110
Rgweekes
Jersey
Hello, I’m looking for a recommendation for a camera kit for a new Defender 110. Screen on/replacing rear-view mirror or on dashboard, with camera outside showing rear end and reversing space. Tried a couple of options, but they can’t get the angle to look down on the rear of the vehicle/spare. Literally to assist driver with reversing in tight spots.
Any recommendations appreciated.
Post #667514 28th Nov 2017 11:00am
bankz5152
If it makes any odds, I fitted my reverse camera inside where the tow hitch electrics go, if you don't tow it's a good spot! Gives a perfect view and avoids the spare entirely.
Post #667521 28th Nov 2017 11:42am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Yep mine is in the same place
Look at http://www.techmoan.com/what-is-the-best-dashcam/ for dashcam reviews
Post #667551 28th Nov 2017 2:42pm
Rgweekes
Jersey
Many thanks - I'll take a look at doing exactly that.
Post #667559 28th Nov 2017 3:37pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Mounted mine under the rear numberplate light;
 My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #667561 28th Nov 2017 4:06pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Mine is in the middle above the adjustable tow hitch.
Camera working out fine. The mirror mounted screen and recording unit not so much. Had worked well for three months now freezing and glitching. It will get another reboot and see if it clears up. If not it is going back for a replacement.
It was a cheap Amazon Chinese jobby so was proof of concept as much as anything that I could get a good reversing camera on a 300 TDi 110. I have been happy reversing by touch in previous Series Rovers but I felt I should get more responsible now there are small children living near me. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #667565 28th Nov 2017 4:35pm
bankz5152
I tried my cam under the plate light, found the view utterly useless, then moved it.
Post #667574 28th Nov 2017 5:20pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
I've got mine under the number plate light too, it's fine with a wide angled camera, very discreet and out the way. It also gives a good view of the tow ball and anything else that might be first to hit anything your reversing to
Post #667581 28th Nov 2017 5:50pm
Stacey007
Had mine under number plate light for well over a year, As I didn't want to drill the car. Ideally I think near the rear water wash? would be the best place.
Hook up to a trailer on my own, can get very very close to what ever is behind me.
Find it very useful.
Post #667615 28th Nov 2017 7:52pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
Stacey007 Is the dash screen one of the flip up ones also is your system wireless?
Bankz5152 The camara fits persfectly who is the supplier?
Also a general query which is better wired or wireless?
Post #667799 29th Nov 2017 9:35pm
grafty99
I also have a question, do all aftermarket cameras have those lines displayed? Is it a configurable option? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #667801 29th Nov 2017 9:39pm
bankz5152
I tried 3 cams all had lines which are "parking lines" cant remove them. Though you could use any camera in thrre as long as it works with your screen, may need some.wiring adjustment though.
Camera is an ebay special cost aboit £15
Post #667852 30th Nov 2017 5:48am
grafty99
Ah ok, my OCD would struggle with that if the camera wasn't centrally mounted Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #667861 30th Nov 2017 8:09am
Stacey007
Hello
Mines wired I believe will work better that way?
I've also changed the flip up screen for a 4.3" screen
works great though and very handy
Post #668068 30th Nov 2017 9:10pm
foggydave
I have been looking on Ebay and a lot of the screens have 2 connectors 1 x main 1 x aux. It seems you can have 2 camaras attatched and flip between the two. I presume this would be for front and rear camara views. Although in the case of the Defender with spare wheel cuasing sight problems you could mount 2. One above the rear door and one in the hole in the rear crossmember
Stacey007 I was going for the flip up version. Why did you change??
Also with the pictures of screens on the facia. Are these permanent fixtures??
Post #668153 1st Dec 2017 7:12am
