![]() | Home > Puma (Tdci) > 40.000 km Service |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Well,
Today our Defender went to the 40.000 km checking. Several things to be worried (not too much, but): a) Oil leak in the rear part of the transfer again ![]() b) Oil leak in the union between the rear prop shaft and the diff. c) Driver door stooper doesnt work d) Misaligned Rear door. So much oil leaks in 40.000 km! I don't like to imagine what will happens when the guarantee will finish. ![]() ![]() 4 days to make all this work, So we will see on Friday. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
What's the issue with your driver's door?
I noticed the other day that my driver's door doesn't stay open but just swings shut (mostly onto me as I'm climbing in). |
Atlantd
The same that you. And is quite awful in special when you are in a slope. Same problem was detected in the past in almost all doors. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I'd be interested to see if they fix the door stopper. I had just assumed there wasn't one
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Same here, just the drivers door,none of the others. Eveything else is OK though. 130 crew cab
98 V8 Disco |
All the doors should have it, rear door included (at least in mine)
In my case the passenger, the rear door and one of the 2d row doors has been fixed in previous visits to the dealers. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge Last edited by Eduardo on 29th Jan 2009 10:24pm. Edited 1 time in total |
Just I speak with the dealer.
Transfer leak was a bolt not sealed properly when they changed the seal some time ago. The leak in the rear diff was the seal (already changed) Driver door stopper were also fixed Brake pads changed Windscreen wippers changed Door seals also was adjusted Some greasing works Rear door adjusted So I'm ready to start my vacation period (2 weeks only ![]() I promise some photos... Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Enjoy bud
Enjoy your holiday Ed. 2.4 90 XS
