Home > Puma (Tdci) > Turbo oil feed pipe replacement
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Hi,
I am fitting a new turbo, and to keep the warranty intact I need to fit a new oil feel pipe which I have already bought.
Before I start taking bits apart, does anyone know where the other end goes. From a quick inspection it looks like a load of stuff on the front of the engine has to come off.
Has anyone changed one?
Post #667107 26th Nov 2017 8:47pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
It will pick up towards the lower end of the block, under the turbo,
Just follow the pipe downwards from the turbo. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #667113 26th Nov 2017 9:21pm
v8bobber
Yes that’s the problem. Is dissapears out of view. Even with the turbo off you can’t see where it goes
Post #667137 26th Nov 2017 10:34pm
ian series 1
Here....
Right hand side of sump, just above where the block meets the sump,
90 degree bend is the turbo drain,
Smaller one is the dipstick. Thumbs Up 80" 80" 86" 88" 90"
Post #667281 27th Nov 2017 3:39pm
v8bobber
Thanks for the pictures but it was the oil feed pipe I was asking about not
Post #667314 27th Nov 2017 6:23pm
v8bobber
.......the oil drain pipe
Post #667318 27th Nov 2017 6:30pm
I seem to recall that the feed pipe connection to tbe block is obstructed by the huge bracket that holds the alternator and (if fitted) air con compressor. I did strip one off my spare engine a few months ago and I seem to recall that that daft bracket had to come off first.
Post #667340 27th Nov 2017 7:21pm
ian series 1
I'm sorry, I read the post wrong Embarassed
The FEED pipe is a tricky one,
Once the turbo is removed you will be able to see where it goes.
If I can get another decent photo at work tomorrow I will post it for you,
Although it won't show you much more than you can see yourself,
Other than it being high up on a lift. 80" 80" 86" 88" 90"
Post #667357 27th Nov 2017 7:53pm
ian series 1
Here you go!
This is on a Transit, but the same set up,
Although it's trickier to gain acsess on the Defender!
Just above the PAS pump, you will see the pipe and banjo fitting.
 80" 80" 86" 88" 90"
Post #667466 28th Nov 2017 9:48am
So the pipe runs right across the front of the engine to the nearside?
I can honestly say that I had completely forgotten that from when I stripped one off my spare engine!
Post #667496 28th Nov 2017 11:11am
ian series 1
No,
It runs from the turbo downwards and picks up between the alternator and PS pump,
Right on the corner of the block.
Post #667501 28th Nov 2017 11:26am
I may be having a senior moment, but isn't the PAS pump on the nearside on a Puma?
Alternator and Aircon on offside, PAS, fuel, and water pumps on nearside. Or am I have a major and about-to-be-very-embarrassing brainfart?
Post #667503 28th Nov 2017 11:30am
ian series 1
Laughing
No, I did mention that this is a 2.2 Transit engine,
I know the anciliarys are in a different location, but the feed pipe is in the same spot.
I did have a Defender in this morning, but you could not see the pipe,
On a Transit everything is a bit more accessible Thumbs Up 80" 80" 86" 88" 90"
Post #667505 28th Nov 2017 11:36am
Aha, no need for me to report to the old folks' home just yet then!
In the picture below taken from the Puma WSM the feed pipe union can be seen just below the turbo, which (thankfully) is where I though it was (phew!):
If you remove the engine from the vehicle, or remove the alternator (and aircon compressor if fitted) and then the alternator mounting monolith it is quite easy to find!
Post #667512 28th Nov 2017 11:53am
