![]() | Home > Technical > Defender 2014 2.2 engine number |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 ![]() ![]() ![]() |
Found it.
Its on the front cover behind the drive belts. It is just a sticky label that is peeling off and is very hard to read. It seems strange that there is no permanent stamp on the block. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
It'll be stamped on there somewhere i expect. It's probably just impossible to see without stripping down the engine. The label is just there to put it in a more accessible place so they can scan it on the production line - ie. so they can track the engine along the line at Dagenham and so they know which unit goes in which car at Solihull.
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Think the 2.2s are stamped on the block behind the high pressure pump?
As above, all blocks are stamped from factory aswel as a sticker. Ford never seem to follow a pattern, the old Duratorques were in various locations depending on the year. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
