![]() | Home > In Car Electronics > A question for the connector gurus..... |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
You need Paul Mc on ‘‘this forum PM him
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6672 ![]() ![]() ![]() |
Looks like a wide-terminal version of the Econoseal used on the lights.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17815 ![]() ![]() ![]() |
It's actually quite a lot bigger than an Econoseal, more the size of a Superseal.
OK I'll have a dig about for you
OK Scrub that
It's not that, wrong shape
Have you got the pump to hand? If so can you measure across the widest part of the connector - across the "ears"
![]() Click image to enlarge ![]() ![]() |
Not to hand, it's at home. I will measure tonight.
I have found a GM part that looks promising, but I can't find a UK supplier:- https://www.carid.com/standard/headlight-w...-1347.html https://www.amazon.com/ACDelco-PT1447-Orig...B000C9U1W6 Amazon.com will ship to the UK, but surely there must be something home-grown! |
I think I've found a match but need the dimension to confirm. Also measure the width of the metal tabs if you can
![]() Confirming if they are 4.8 or 6.3 will do, doesn't need to be exact ![]() ![]() ![]() |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
it looks a ford connector i had on my fiesta etc
Thank you! ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20876 ![]() ![]() |
Looks a bit like a 2.8mm blue Superseal, which are typically higher current. _\Hennessey|Venom| F5/___
___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Doubt if it's Ford as the use of the connector pre-dates their ownership of LR.
