Home > Puma (Tdci) > Clutch Soft and Struggling to Engage Gear When Warm
fbaird03
Scotland 2007 Defender 90 Puma 2.4 HT Galway Green
Hey,
I'm new to the forum as I've recently just bought my first 2.4 2007 90.
After driving a while on the motorway I noticed no resistance in the clutch pedal until the very bottom. The clutch pedal would sometimes stick down in the footwell and struggle to engage a gear.
After pulling over for a bit it would be ok again.
I have just replaced the master cylinder and flushed through the fluid as it didn't look clean.
Bled the clutch and all felt fine on short drives. After driving on the motorway again, the same is happening...no resistance in the clutch pedal. Could it be heat related?
Really don't want to go down the gearbox out and replace clutch/slave cylinder without asking around.
Hope you can help,
Thanks,
Fraser
Post #665887 20th Nov 2017 11:04pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Fraser
welcome to the forum
It does sounds similar to the master cylinder fault that I had recently - mine was fixed with a replacement and has been good since..
It may be that the clutch/slave are on their way out .... the pumas do tend to go though clutches a little quicker than the other earlier defender models as as yours is 2007 it may be that this is time for a new one.
there will be those who have more skills in this area who will give more advice soon
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #665892 20th Nov 2017 11:16pm
Saley
United Kingdom 2009 Defender 110 Puma 2.4 CSW Bronze Green
Have a similar fault on my 2009 2.4 done 75000 miles. 2 hours on motorway and pulled off and could not disengage gear. Has played up off and on for a few weeks someone advised slave cylinder probably needs to be changed and it is in the bell housing. Just about to tackle it but would like to know if this seems the most likely fault. Sometimes will not go in gear but turn off engine and can select gears no problem. Gearbox out ?
Post #666151 21st Nov 2017 11:23pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Before you commit to taking the box out, change tha master cylinder,
They are cheap to buy, and more of a common fault with weak and wearing seals, rather than the concentric slave,
In my experience, these give very little trouble in opperation.
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #666167 22nd Nov 2017 8:15am
Saley
Many thanks Ian I will replace the master cylinder and see if it cures it. Will post the outcome.
Post #666290 22nd Nov 2017 7:43pm
fbaird03
Thanks guys, I replaced the master cylinder but still goes a bit soft after a motorway journey. Will try bleeding the clutch again but think I might have to go down the new clutch and slave cylinder.....but that would be after Xmas Very Happy
Post #666513 23rd Nov 2017 9:40pm
ian series 1
What's the mileage on the clutch/slave cylinder? 80" 80" 86" 88" 90"
Post #666539 23rd Nov 2017 10:27pm
agentmulder
Kuwait
Went through this two years back.
Master solved it for about a month then back to the same ol' shenanigans. New slave and while we're at it replaced clutch too, fine since.
Master can be done in the driveway, bit of a fiddle space/knuckle wise and then there's the bleed but all doable. Thumbs Up Solved the bowel problem, working on the consonants...
Post #666588 24th Nov 2017 7:31am
