Home > Puma (Tdci) > 2.4 Puma on losing streak HELP
Mack
2008 Defender 130 Puma 2.4 HCPU Chawton White
Hello mates, I come to you for help and guidance in this my toughest motoring year. My 130’s tough and reliable “attitude” has been interrupted this year (233k km), when I finally seemed to have everything sorted out, new issues appeared yesterday.
Overall issues throughout the year have been (already replaced):
Vacuum pump
Starter motor
Clutch kit
Slave cylinder & master cylinder
Clutch adaptor
Heater valve
Water pump
VCV
Alternator (serviced)
Battery (it lasted a long time, replaced the oem varta with lth red hitec)
Expansion tank (was still ok, replaced it for precaution)
The starter motor was what gave in first, right after I replaced it clutch and vacuum gave in, so it was parked in my garage for a few weeks (with the brand new starter motor and battery) so I started it everyday for a few minutes to keep things fresh meanwhile I waited for dhl delivery on parts.
After the parts arrived I took it to the shop where they replaced the clutch kit and vacuum pump. When I parked it there it was starting immediately.
When I went to pick it up, it had a hard time starting I had to insist several times to get it started but it got going so I drove home. The mechanic said probably they left a light on and the battery got low on juice.
Troubles persisted so I removed the alternator and took if for service, and also recharged the battery.
After re installing everything (the trouble starting pretty much felt as lack of electrical juice), the starter still has a difficult turn and didn’t start anymore after 2 or three troubled operations (last 2 times it worked did it at mot when they did a test on the booster, made a crushing noise had some burnt smell but then started perfectly for the last time, had good luck on that one) when I push the break pedal the park lights blink, the check engine light went on and there is now an unusual noise in the area of the injectors.
I have checked and re checked and triple checked the alternator, starter and battery connections and problems persist ( doesn’t start, check engine light is on, electrical weirdness on occasion everything is fine then lights go crazy) .
What else should I do? Any ideas why it was starting perfectly before clutch swap and doesn’t now, could there be a flaw in the installation?
I would very much appreciate the help with this one, my 130 is my workhorse (I’m a surveyor) and it’s pretty much the only rig that 100% meets my requirements.
Thanks in advance for the urgent help.
Mack
PS. Dealer not an option, they just replaced their mechanics and the new guys know nothing about Defenders specifically pumas which are rare here.
Post #666449 23rd Nov 2017 3:10pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
If you had the box out, check the earths on the transfer box. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #666452 23rd Nov 2017 3:44pm
mk1collector
And I've read the relays under the seat can come loose causing random dash lighting. Ray
My build thread
Post #666454 23rd Nov 2017 4:41pm
LR90XS2011
ian series 1 wrote:
If you had the
what he said look for a dodgy earth cable DEFENDER 90 TDCI XS,
Post #666488 23rd Nov 2017 8:17pm
^^^^ This is exactly what I had once. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #666491 23rd Nov 2017 8:24pm
ian series 1
i had one ring terminal that had broke the ring off of the terminal body,
It was only the insulation that held it together.
ABS light on,
TC randomly flickered
Tail lights not working
Occasional symptoms of a flat battery.
Heated Windows not working.
All of these would happen at random times, and in damp conditions it got worse,
I only found this after checking with a multimeter,
Visual inspection wasn't good enough.
Hope you get it sorted, I know how frustrating these problems can be,
I think most of us on here have had a visit from the "Lucas gremlin" at one time or another Laughing 80" 80" 86" 88" 90"
Post #666494 23rd Nov 2017 8:43pm
Mine was dirty and loose, but you'd never notice to look at. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #666511 23rd Nov 2017 9:38pm
Mack
Hello mates thank you all for your replies. Both of the earth cables that go to the transmission were not even bolted on. After screwing them in place, the rig feels like new again 😁, what a headache for such a simple thing. Thanks again to you all, this forum is really helpful!
Mack
Post #666522 23rd Nov 2017 9:58pm
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #666530 23rd Nov 2017 10:16pm
agentmulder
Kuwait
I love reading these threads Wink
When you're back rolling with just one little fix, no more worries and time for a beer. Mr. Green Solved the bowel problem, working on the consonants...
Post #666589 24th Nov 2017 7:36am
discomog
Glad you are sorted with such a simple fix. It's nice to hear that the Defender 130 is the only vehicle for your work. Thumbs Up Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #666610 24th Nov 2017 9:35am
