Home > Puma (Tdci) > Immobiliser light
Willbof
Wales 2012 Defender 110 Puma 2.2 XS CSW Zambezi Silver
Immobiliser light
Hi, recently purchased a 2012 defender and have a question about the immobiliser. If I unlock the landy and start the engine reasonably soon after the light goes out no problem. If I leave it unlocked, don’t start it quickly or stop for a while and restart the immobiliser light stays solid. I’ve driven around with it on and nothing happens it just keeps going. If I switch the ignition off then back on the light goes out. Is this normal?
Thanks in advance
Post #665787 20th Nov 2017 5:29pm
steve E
Wales
The light on the left if it stays on, should mean your battery in the fob needs replacing
Post #665793 20th Nov 2017 5:42pm
JellyBean
I am so going to try this today! I've had the same issue for months wondering what on earth was happening ......
Post #665991 21st Nov 2017 12:27pm
hornet
From LUCAS 10AS ALARM- System Overview:
Low battery error: This configures the alarm to notify the user via the Security LED either on the first receipt of a key code in which the low battery flag is set or to wait until it has received a number of them in succession. The exact number is determined by the value stored in the LOW BAT COUNT box.
Battery Error: When set to ENABLED this configures the alarm to notify the user via the security LED that the plip has a low battery in accordance with the other settings which affect this function's operation. When set to NO the function is totally disabled
Post #666039 21st Nov 2017 4:35pm
Willbof
Hmm, bit strange because it only happens after I’ve stopped, not locked it and started it up again. I would’ve thought a low battery alarm would be on all the time?
Post #666058 21st Nov 2017 5:21pm
steve E
Wales
Changed the batteries in mine and it's fine now
Post #666127 21st Nov 2017 9:54pm
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Does the motor still crank but not start if the immobilizer is on?.
Post #666160 22nd Nov 2017 5:22am
90dv
United Kingdom 1990 Defender 90 200 Tdi CSW Keswick Green
10AS function means it'll allow the vehicle to crank while doing security check with PCM through IPK. If the security check isn't successful (no fob detected) the vehicle will stop cranking. Usually get crank and fire but then cuts out immediately. This is done to avoid a delay in cranking while fob immobiliser code is checked.
Post #666179 22nd Nov 2017 10:17am
Willbof
Runs fine, can drive around no problems except a bright red light in my face
Post #666289 22nd Nov 2017 7:42pm
PRENT1
United Kingdom 2011 Defender 110 Puma 2.2 XS CSW Santorini Black
The other night i returned to my 2.2tdi to find neither of my fobs working, on opening the car with my key no central locking. when i put the key in the ignition no turn over but triggered the alarm..
AA came no joy tried several things ECU read; fault code/s:System : Engine control - 7MF / Diesel CR/EDC ZSD 422 Status :B1206 - Crash data stored. Error Message : Malfunction
Flat beded it to my local LR garge they have told me £2k to replace the alarm module(fried was the terminology) and some wiring.
Any ideas in the Bromley, Kent area?
Post #683592 2nd Feb 2018 11:43am
Willbof
20amp fuse under the steering column!
Post #683593 2nd Feb 2018 11:49am
Willbof
Top right hand side if I remember correctly
Post #683595 2nd Feb 2018 11:50am
