Home > Maintenance & Modifications > Seat upgrades |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
hi will,
i bought a 200 tdi that already had the seats re-trimmed in outlast material and to be honest it was only fractionally more comfortable than my old neptune cloth originals. As i was in the market for replacement seats i did have a good look at their options at at Billing and came to the conclusion that if i had to get new seats then i would personally go for the scheelman (sp?) that exmoor do, with the lift out base, in neptune fabric if it was available. (the elite was comfortable but the scheelman seamed to have either a longer base or more support under the leg that i found more comfortable). Also mudstuff's seat risers make seating more comforable and i am only 5'7" hope this helps |
6th Apr 2011 11:02am |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
I have been considering upgrading the seats in my Defender and tried the elite seats out at the indoor 4x4 show. I also found that the seat base was too short. The back offered a bit more support and was higher than the standard seat but, when you consider the whole seat (and cost ) as a replacement, didn't think it was worth it.
Tony |
6th Apr 2011 12:46pm |
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Apr 2011 1:26pm |
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 |
Click image to enlargeπ I have recently fitted Exmoor Le Mans Seats, very happy. Massive improvement over standard seat.[/img][/img][/url][/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
7th Apr 2011 12:42pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
good job paul
the only prob is, then i can put M&M seat covers and i love these covers................. www.newfoundland.gr |
7th Apr 2011 1:40pm |
James R Member Since: 20 Mar 2011 Location: Hampshire Posts: 9 |
Those seats look great! Do you have to have them with 'Exmoor Trim' stitched on them. Defender 110 XS 2007 Puma
Formerly :- Range Rover Classic Autobiography Discovery 3 90 SW |
7th Apr 2011 9:44pm |
I had this pair as a special order with the Land Rover logo fabric supplied by Trakkers.
I would have thought you could get the logo stiching dropped if you want. Very easy to install, comes with everything you need as a kit and you can have seat heaters fitted as an option. They slide rearwards much further than the standard seats with out the need for a riser kit and provide excellent leg support compared to std seats. |
8th Apr 2011 7:58am |
kosma_r Member Since: 28 Apr 2013 Location: Polska Posts: 5 |
Could you please explain how did you mount Scheelmann seats? |
4th May 2015 6:35pm |
