Home > Maintenance & Modifications > 2.8 iveco engine
Oldyellar
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
2.8 iveco engine
Just been scrolling through eBay and noticed someone selling a Santana ps10 engine and box adapter
https://m.ebay.co.uk/itm/Landrover-engine-...SwYVlZ~LZi
Has anyone done this conversion ? Seams like it could be a cheap worth while conversion.
I've had a few iveco through out my time and they have been very good engines.
I think in a old 90 it would be lovely
Post #665829 20th Nov 2017 8:40pm
pannawonica
Australia
Why when you could fit the transit diesel, just curious?
Post #665915 21st Nov 2017 2:16am
ibexman
Frank Elson LR mag journalist used to run 2.8
Post #665916 21st Nov 2017 3:33am
Oldyellar
The transit puma diesel is the best imo even further so the tddi puma of the mk6 transit where you can get the mechanical fuel pump and run off no electrics .
It just looks like this is a easy retro fit for for older 110 and 90 as a pose to the tdi and also cost didn't seam high
Post #665931 21st Nov 2017 8:55am
zsd-puma
The TDDI was a pig, so many catastropic failures on those, and they were gutless compared to the TDCI version. By the time they got to the TDCI they'd been and sorted out most of the other faults with the engine too. There was a lot more development done on them beyond the fuel system. Much like a 2.2 is very different to to a 2.4.
The old Transit Di version of York engines were pretty bomb proof mind you, but noisy and rough by modern standards.
The 2.8 Iveco is a good lump, but it's probably easier to fit a 3.2 Puma engine if you're fitting to an existing Puma vehicle.
Post #665999 21st Nov 2017 12:53pm
miker
The way the UK is going with diesels, I wouldn't be swapping any diesel engine in! I've put plans to tune my td5 on hold until I decide if long term a petrol swap may be a better choice
Post #666003 21st Nov 2017 1:15pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I worked for an Iveco dealer for 13 years and did my apprenticeship when the 2.8 (8140 engine) was fitted to Daily vans.
They where a dependable unit and ran for many miles with no trouble as long as servicing was kept up.
But they were last produced in 2004/5, only 8 valve (albeit had lots of bottom end torque) so no were near as refined as a puma engine.
If i had a Tdi i would consider this as an option as in my view it is a better engine than a Tdi, but has electronics (unless you get the earlier 106hp variant with rotary fuel pump) and being early common rail injectors have been known to cause non start issues.
Overall they was a dependable engine to Iveco/Fiat like the Tdi was for Land Rover.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #666010 21st Nov 2017 1:53pm
Oldyellar
I've only ever had one failed puma and it was a 2.2 2009 170k engine the cam carrier snapped, I've had a Censored load of tddi and although a bit more unrefined they were all good the 125 ps had plenty power had one with 380k on it sweet as a nut , however the 75/90 and the 2.0 were so prone to fuel pump failing
Post #666090 21st Nov 2017 7:57pm
zsd-puma
They were forever blowing coolant hoses in our fleet and we had several with piston failures. awful rough old things, the older York based lumps were rough but at least they were robust.
Apart from the EGR the electronics on the TDCI pumas are very reliable. Even the bits that do fail, like the VCV and EGR, fail mechanically rather then electronically.
Post #666130 21st Nov 2017 9:58pm
I was going to say but it has already mentioned that probably a 3.2 TDCI would be a better option. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #666143 21st Nov 2017 10:17pm
zsd-puma
I think someone did a 2.8 version of the 300TDI, i forget what it was called.
Post #666153 21st Nov 2017 11:30pm
AJC
called TGV if I remember correctly
Post #666164 22nd Nov 2017 7:22am
Oldyellar
It would be a better option no dout however i was basing the swap on a landrover 90 where the comon swap is a 300tdi/200tdi
Post #666169 22nd Nov 2017 8:37am
Mo Murphy
I really don't see any reason why it shouldn't work out to be a good transplant providing the engine you buy is in good repair.
These engines have a reasonable enough reputation in the Santana and at the time of their launch in the Santana were considered superior to the Tdi.
Old transit engines belong in old Transits, as do modern Transit engines, come to think of it 😆😉
50 Shades of Pennine Grey
Post #666208 22nd Nov 2017 1:11pm
vito115
i was going to fit one in a defender years ago, i remember going to Billing and speaking to frogs island as they were fitting the 2.5 iveco engine but when i said i was after the adapter plate etc the guy became very cagey and wouldn't say where they were getting them from, i think it was an iveco dealer in Southampton ? Anyway cut a long story short the Landy got nicked & i flogged the engine !
Post #666877 25th Nov 2017 7:33pm
