Home > Technical > 2009 2.4 TDCI Defender Starting Issue (10AS? IPAC? ECU?)
Page 2 of 3 <123>
Bluest
The cam shaft sensor, if it fails, will allow the engine to turn over but not fire. It’s happened to mine twice. Maybe yours is intermtantly faulty. It won’t show a fault code either. If you’ve got access to the Lynx diagnostics I think you can view the cam sensor output to see if it’s working. Sensor is only used on start up, so you f it fails whist running you won’t notice until you next try to start the engine. The sensor is easy to change and from memory not too much expensive from Ford. 2007 110 TDCi Station Wagon XS
Post #665875 20th Nov 2017 10:34pm
olliecracker
United Kingdom 2009 Defender 110 Puma 2.4 HT Keswick Green
Yeah Showing just over 200Rpm on turn over
Post #665879 20th Nov 2017 10:38pm
olliecracker
Ahh okay! Thankyou!,
I'll look at getting one tomorrow! Smile
Post #665881 20th Nov 2017 10:39pm
Bluest
Somebody diagnosed my cam sensor using the Lynx, but I don’t know how to do it. I would try to do that before buying a sensor in case it’s money wasted. 2007 110 TDCi Station Wagon XS
Post #665882 20th Nov 2017 10:44pm
olliecracker
Ahh okay, I'll have a play tomorrow after work! - If not, I'll just get one from GSF car Parts
Thank you Very Happy
Post #665884 20th Nov 2017 10:55pm
olliecracker
Hi again!
This afternoon I went back to the Landy... Fired up straight away... No problems at all! Haven't touched anything. I then went on to look at the cam sensor and all looked fine when checking with a multimeter. Could take it to work and check with an oscilloscope but I'm pretty sure it's okay.
After, I disconnected the immobiliser coil (AMR4897) that fits around the ignition barrel and just as before, it fired up again.. Does my immobiliser do anything? - looking in lynx diagnostics, the passive immobiliser and theft system are active. But I've disconnected the only part that would actually recognise the key.
I probably will go back to the Landy tomorrow and it won't start Laughing
Nanocom should be arriving on Tuesday! Thumbs Up
Thanks,
Ollie
Post #666706 24th Nov 2017 6:49pm
dorsetsmith
But I've disconnected the only part that would actually recognise the key. (not so all in the way its set up )
YES it run your interior light or not Whistle
Post #666709 24th Nov 2017 7:00pm
olliecracker
Does an immobilised 10AS stop the engine from cranking? - If it does then I can rule that out and just check the signal is getting to the ipac.
Update: Plugged in the Nanocom today and the Passive immobiliser is disabled, and it's set up for TD5/MEMS.
The lynx diagnostics read that the passive immobiliser was active but I'm going to trust the NANOCOM
Post #667375 27th Nov 2017 8:41pm
olliecracker
2 faults found on the Nanocom
Post #667605 28th Nov 2017 8:20pm
olliecracker
Fixed!
It was the IPAC not passing the signal onto the ECU inttermitently! Got around it with a mod and now it starts everytime Smile
Post #668090 30th Nov 2017 10:56pm
Exwirus
Poland
Hi olliecracker. Could you explane how exactly you fix the problem? Seams i have got same issue Sad what means IPAC?
Post #670213 11th Dec 2017 8:57am
dorsetsmith
olliecracker wrote:
Fixed!
good
Post #670214 11th Dec 2017 9:03am
Exwirus
Poland
Ok i uunderstood that IPAC is instrument cluster, right? I checked signal from AS10 into IPAC and it's changing when fob is close to immortal coil. But I don't know how to check outgoing signal to ECM? Signal is 0.9V all the time.
Post #670292 11th Dec 2017 3:41pm
Exwirus
Poland
I replaced also CMP sensor. No results unfortunately Crying or Very sad
Post #670293 11th Dec 2017 3:43pm
Exwirus
Poland
Thanks a lot for advice and help. Was the same issue lack mobilisation signal to ECM. Solved with the IPAC bypass.
Post #670785 13th Dec 2017 9:31pm
Page 2 of 3 <123>
