Home > Td5 > Coolant leak?
Page 2 of 4 <1234>
Djcla
i cant feel any air what so ever coming out Sad
Post #665776 20th Nov 2017 4:57pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Okya you,ve made thta part clera but IS THE FAN WORKING? As in if you go in the engine bay is it spinning? Can you hera it whirring away? Trying to help you but need more info... 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #665778 20th Nov 2017 5:08pm
Djcla
Ok sorry miss understood your question, I'll check the fan is running
Post #665780 20th Nov 2017 5:12pm
rallysteve
Just to clarify, the fan will only operate with the slider in the two lowest positions (lever should click) the upper 2/3 of the slider just allows fresh air to enter at a varying rate at of its own accord.
Post #665782 20th Nov 2017 5:18pm
Djcla
I thought i tried every position , but to start with i had the far right leaver in the middle position which i thought was feet and windscreen. Then the leaver on the left set to the bottom position which i assume is full speed.
Post #665786 20th Nov 2017 5:22pm
dorsetsmith
Also check at the flap in the heater box move when move hot and cold lever and fan speed lever too
1. hot and cold lever is meant to mover top one on heater box, in the cold air position air a round heater matrix and as you move the lever to hot end the flap in box direct air into heater matrix
2. fan speed lever is meant to mover side one on heater box from closed at (0) to open as fan speed lever move down to full speed
3. one more check flap foot well to windscreen have look below in foot well you see small air out let if you remove plastic cal and move the far right lever up and down this flap is meant to move up and down to direct air to foot well or windscreen and both with lever haft way
Post #665794 20th Nov 2017 5:49pm
Djcla
Where on the heater box are the flaps to check ( could not see anything obvious) or do i have to start taking things apart?
Post #665966 21st Nov 2017 11:15am
excossack
AFAIK the flaps are operated by the lever on the top of the box. The end of the cable is clamped and this is what moves the flap in the box 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #665972 21st Nov 2017 11:26am
rallysteve
The lever on the top of the box is Hot/Cold
The lever on the side of the box (engine side) is the flap which allows air into the cab or not (linked to the fan speed lever).
The windscreen/demist/footwell lever is connected to the lower dash section only.
Post #665975 21st Nov 2017 11:34am
dorsetsmith
see up dated post
Post #666018 21st Nov 2017 2:30pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Is the layout of your heater controls?
 Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #666020 21st Nov 2017 2:54pm
Djcla
dorsetsmith wrote:
see up dated post
Thanks i will re check , maybe i was looking at the wrong part as i dont recall any cables on top like that shown in your diagrams
Post #666023 21st Nov 2017 2:58pm
Cactus79
You should also check the long hose which goes from just under the inlet manifold down to the front left of the rad.
It catches on the engine mount and wears away causing a leak. I cut and patched mine before replacing with some Chinese silicone hoses.
Post #666225 22nd Nov 2017 2:50pm
Djcla
I was playing around with the fan control today, shifting it from top to bottom it seems to click 3 times after all the white marks. I can just hear it on the second click and can hear it as expected on the very bottom 3rd click. Next to no air flow on any settings though. I'll investigate further on weekend.
Post #666316 22nd Nov 2017 9:16pm
Djcla
Ok amature hour , topped up coolant but over filled completely ( really not easy to see level), two of us as well lol.. is this big problem do I need to get some out or can I leave it? I ran engine for a minute and it's dropped a bit.
Post #666799 25th Nov 2017 11:44am
Page 2 of 4 <1234>
