![]() | Home > In Car Electronics > ABS sensor in wrong place? |
| hellymoore Member Since: 18 Nov 2009 Location: Sm�gen Posts: 93
Had problem with one of my ABS sensor (left front) and found that left front had low voltage
Has now change it and has the still ABSlamp on the dash, started to disconnect eatch sensor and found out "left front" is the left rear sensor what shall i do? reconnect it as it should be or? The truck is a defender 2001 and I have a nanocom as diagnostic device |
What I know and can look at the wiring,it has never changed since the car has been new. Have just checked to see in the electrical circuit how it is supposed to be.
I must also see how the brake pipes are drawn to the ABS module (it can be adapted to the car) as it also is fitted to DiscoveryII |
ABS problem solved, went through electrical systems and piping systems.
Changed the cable so that it matches the nanocome and suddenly everything works again. probably the brake on the left front wheel caused the error, this occurred after a day offroad with muddylains Now the TC also works as it should |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Good that its fix
I have investigated the problem and found out that is a garanti job on the ABS cablage couple years ago, (prob a axel work)
everyting working fine now |
| All times are GMT |
