Home > Td5 > Missing Pin in Diff Lock Linkage?
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
So looking for some help!! Smile
Recently while driving down a few tracks the Diff Lock decided to give up the ghost! Happily sitting in Low Range but not even feeling like shifting into Lock, although the stick was freely moving!
After getting underneath today, I think there is a pin missing at the top of the linkage at the selector. Question
Anyone able to shed some light on this!!
What size pin/ bolt should be in there?
What's the best way of replacing it?
I have a 2003 TD5 (I think that makes it a LT230TE Transfer Box / R380 Gear box) Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #665567 19th Nov 2017 7:52pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Think there should be a nut and bolt in a TD5 (earlier used a clevis pin and clip).
Mine was missing them also, looking in the back of the Haynes manual I scribbled the following:
Bolt - FB105051L
Washer (x2) - WA106041L
Nut - NY105041L
The parts manual shows it as a standard hex nut, I fitted a nylock to prevent it shaking loose. IIRC the bolt is m5 but maybe worth checking that. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #665571 19th Nov 2017 8:11pm
bogwert
Thanks Harry.O! Thumbs Up
Yeah it looks like a M5 x 25mm. Might go down the stores at work and see what is lying around!!
Using a Nylock sounds like a good shout!! Chris
Post #665574 19th Nov 2017 8:16pm
dorsetsmith
25mm x 5mm bolt with nyloc and 2 plan washers
Post #665582 19th Nov 2017 8:23pm
rallysteve
Or even better, fit an M6x25 as the hole is probably worn anyway. I filed out the slot in the lever arm slightly to get it to fit. Linkage will operate much better than if it is worn with the M5. Done this on two R380s now.
Post #665626 19th Nov 2017 11:14pm
bogwert
Hi Steve,
That’s a good shout. I’ll get two bolts and see what they are like regarding wear.
Think it would be worth throwing a bit of grease in there too? Help keep it loose? Chris
Post #665644 20th Nov 2017 12:34am
