Home > Wheels & Tyres > Bfg mud terrains...
Page 2 of 3 <123>
JOW240725
Jose.Pereira made some interesting comments on tyres here http://www.defender2.net/forum/topic51372....p;start=15 James
Instagram @suffolk_rovers
Post #648199 4th Sep 2017 1:13pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Stick with what you have.
We were digging ouselves out of the dunes with a 2CV rally shoting past. You can pretty much do it on anything.
Post #648250 4th Sep 2017 5:01pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Thanks for the link James, I'm planning on doing that next year as long as I don't miss the registration date again! Interesting read about tyres & pressures really helpful.
Post #648574 6th Sep 2017 10:27am
jst
I currently run 255.85 bfg mts km2 on boost alloys no problem. No spacers.
I took same size to morocco as mts, going again I would take bfg Ats. As prev mentioned pressure and side wall strength are prob more important Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #648642 6th Sep 2017 4:55pm
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
AT's prefered in 235/85/16 or 265/75/16?
Struggling with the same dylemma
Post #648710 6th Sep 2017 10:52pm
AndrewS
Widget wrote:
I'd leave your 5mm GY MTRs on.
When you see the regular cars, vans and motorhomes zooming around you realise that you can overthink Morocco!
Agreed Thumbs Up 130's have feeling's as well you know Smile
Post #648720 7th Sep 2017 1:00am
leeds
Whilst tyre tread depth is important also extremely import is the AGE of the tyre and the extent of age/UV/salt/thermal related cracking/crazing.
A Defender tyre with 5mm tread left on it could be 7+ years and already done 50,000 plus miles and be suffering from old age and cracking plus higher risk of punctures..
In this case lowering tyre pressure may well increase the risk of punctures.
Please carefully look for the AGE of the tyre on the tyre markings and carefully look for cracking between tread blocks and circumferential cracks close to wheel rim and then make a decision.
Brendan
Post #648737 7th Sep 2017 8:07am
Don't tyre's often have the manufactured date on the sidewall anyway? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #648782 7th Sep 2017 1:55pm
jst
yes week and year Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #648815 7th Sep 2017 5:37pm
Timcat
Well back from Morocco & what a fab time, people are so nice enjoyed every minute. Truck needed a rear prop uj half way around apart from that all good apart from a rear rub! The 255/85/16 bfg mtr & 30mm spacers don’t work on the rear with a fully loaded truck.
Any deep potholes & you get a rub on the edge of the rear arches, fronts are fine. Ended up removing the rear spacers & all was fine. Question is how do I get over this? Leave the rear spacers off( did 2500mls with just the front spacers) 2 inch lift? Any thoughts, it’s standart at the the moment but carries some weight as it’s an overlander ( Airtop tent, expedition rack, rear racks ect) Thoughts?
Post #665468 19th Nov 2017 11:26am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Just shave the arches a bit.
Mine needed a good shaving with the 255/85R16 on the -25mm offset rims.
You can't really notice they were modified
Post #665902 21st Nov 2017 12:10am
mk1collector
Take the rear spacers to an engineering place and get a few mill shaved off the back if it's only just catching. Ray
My build thread
Post #665903 21st Nov 2017 12:14am
Arierep
Sorry, but I fail to understand how modifying an already sensitive structural component and then end up with a different front and rear track is preferred to run a few mm off the inside of a pair of plastic wheel arches.
Plus, on an overland vehicle you want every mm of track width you can get
Post #665904 21st Nov 2017 12:24am
Timcat
Thanks for both replys to this, I don’t really want to start messing with suspension lifts ect as everything works as it is & should we have a problem whilst away it can always be fixed ( problems if it’s bespoke suspension)
It only rubs on the near side arch for some reason ( everything loaded equal might be a soft spring) My thoughts at the time we’re, spacers off or let it wear its self down ( the truck it’s self is mint condition even though it’s been well used off road) so would need to shave both rear arches & have them re-painted silver.
As for having the spacers taken down, I’ve read somewhere that 25mm is the bare minimum for spacers & I think it’s going to be a bit more than that to clear.
Post #665927 21st Nov 2017 8:38am
JOW240725
Sorry to go back over things Jose but for clarity are you running spacers with your Wolf rims? TIA James
Post #665950 21st Nov 2017 10:38am
Page 2 of 3 <123>
