Home > Technical > rear wiper died
Procta
rear wiper died
what's the story on these dying? I have not long replaced the loom and motor, this was the 1st time it was used last night. Sad
only went down the road and then it had stopped!
I am going to check some fuses in case something has bit the dust. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #657249 14th Oct 2017 2:05pm
Procta
no fuses for the rear wiper system by the looks of it, I saw how much a replacement goes for £100! Shocked
I am going to get a mate to check the electrics 1st before I go down that route, took some digging to find a replacement too!
a few second hand but I am not paying 30 quid on wards for a second hand switch, that could be knackered. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #657630 16th Oct 2017 5:13pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
When i first got my 110, the rear wiper would work a short while then stop mid sweep.
Was about to trace wiring when i noticed the previous owner had adjusted the spare tire carrier such that the wiper arm partially contacted the tire. It would sweep several times then get tired of fighting the tire and stall.
Adjusted the top bolts stops on the genuine carrier to bring the top of the spare out 1/2" and all now good.
Perhaps a long shot, but perhaps check there is no interference?
Patrick
Post #657961 17th Oct 2017 8:27pm
Procta
I have been hearing a clicking noise, from the motor, and its warm. So something isn't right there, any one got any ideas? Chances are the motor is cooked. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #665436 19th Nov 2017 2:26am
miker
Give the motor a strip down. Mine never worked, and the motor and gearbox were seized solid and rusty. Might just need a clean and grease!
Post #665443 19th Nov 2017 6:01am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Before you shell out on a new motor, check that the spare tyre isn't catching. Mine packed up mid sweep (after I had some new tyres fitted), and it was due to the spare catching. You may find the reason the wiper is getting warm is because it's trying to continue the sweep and park but unable to due to the tyre. I was lucky as I discovered it was the spare before the motor cooked itself.
Post #665463 19th Nov 2017 10:25am
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I've had one fail where the magnet had detached from the casing, a bit of araldite and it was fine again. They're simple things so definitely worth stripping down and taking a look at. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #665561 19th Nov 2017 7:28pm
