Home > Maintenance & Modifications > Twisted mesh grille
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Twisted mesh grille
Do any of you guys know where to get it or if there's any other options which give a similar effect?
I've had a look at their site but I can't see it listed... unless im being blind...
 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #663309 11th Nov 2017 1:57am
ibexman
Post #663314 11th Nov 2017 2:27am
Kit
That's their other product which only fits 07 onwards defenders I believe, same as the Zunsport grill
I did find this which is growing on me:
http://www.4x4overlander.com/product/nakat...-silver-2/
Are there any LR badges that would easily mount on that?
Ideally I would still like to get that old school mesh effect like the twisted pic in my original post 1993 200 Tdi 90 CSW
Post #663315 11th Nov 2017 2:33am
5 POT
United Kingdom 2005 Defender 110 Td5 SW Java Black
I think the difference for their new style mesh is it has to fit with an air con panel. That mesh in your photo was just some wire mesh painted and drilled through the panel - I am sure DIY? I asked them about it before on my non air con td5. Problem is I didn't want any of the fixings showing on the front which is why their newer grille is better as no fixings are shown.
That is the Naka grille you can get from 4x4 Overlander in the other photo. I suppose you could put two holes in the heritage badge and just attach with bolts throught the grille?
Post #663385 11th Nov 2017 11:31am
Litch
My Nakatanenga Heritage grill with Artmin alloy badge.
Fitted the grill in late 2010 but after just a couple of years there were already some spots of corrosion which had to be treated. Bought the badge from Gavin in 2013, as many on here will testify his work is excellent.
 ONE LIFE, GET IT!
Post #663498 11th Nov 2017 6:59pm
Kit
I think i've worked out a way of doing it myself to achieve the same finish as the retro grill in my original post, i'm going to see if I can buy a spare front panel off ebay to experiment.
Twisted came back to me today (good customer service!) to tell me it was a custom job they did which lead to their stage one grille package.
Do you have anymore photos please Litch? 1993 200 Tdi 90 CSW
Post #663606 11th Nov 2017 11:59pm
Litch
"Do you have anymore photos please Litch?"
Photos of..........................? ONE LIFE, GET IT!
Post #663815 12th Nov 2017 9:20pm
Kit
Showcasing that black grille 1993 200 Tdi 90 CSW
Post #663841 12th Nov 2017 10:11pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
A similar one here which I have been considering https://www.ebay.co.uk/itm/Landrover-Defen...1438.l2649
It looks very similar to the Zunsport version, albeit it a lot cheaper. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #663938 13th Nov 2017 2:12pm
leeds
Here you go Kit
Black Heritage grill alongside black heritage light surrounds.
Below the Heritage grill is a Nakatanenga discrete winch bumper with a Superwinch fitted
A sideways view
Brendan
Post #664049 13th Nov 2017 9:39pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Some 1" square stainless steel welded mesh gives the same effect as the twisted grill. The stuff I used is 3mm diameter mesh with a strip of white plastic edging around it. Would be just as easy to put the mesh behind the panel and bolt through the original grill holes. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #665285 18th Nov 2017 1:59pm
Hazza
Post #665286 18th Nov 2017 2:00pm
Looks like that's sucking a dummy Brendan Laughing QRZ 2e0vpf
Post #665297 18th Nov 2017 3:15pm
JOW240725
TMD Tuning and Defender Upgrades (I think it was) also do Series grille sets for Pumas. James
Instagram @suffolk_rovers
Post #665316 18th Nov 2017 5:21pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Corrosion on the Nakatanenga grill after a couple of years? I thought their stuff was supposed to be excellent quality.
Litch, can I ask how you afixed Gavin’s badge to the grill? It looks like you used rivets but I would have thought the grill mesh was too thin to rivet through?
Post #665322 18th Nov 2017 5:30pm
