![]() | Home > Technical > Defender TD5 Diff Lock Positions |
There are only two states for the diff - locked or open.
There are three positions for the transfer box - high, low and neutral. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Grannville Member Since: 12 Nov 2016 Location: Isle of Skye Posts: 28 ![]() |
I know there are 3 positions for the ratios, and the diff lock can either be open or closed, it is just strange that there is an 3rd position on the box itself that is inaccessible on my machine, as in when you have the lever to the left it is in the most right hand position on the box. then when you have the lever in the middle position. i.e neutral it is in the centre position on the box. then right hand side for the lever is left hand side on the box. diff open.
There is a video some where if a bloke changing it with a spanner..... 2 secs here he is with his mate james with his nipple |
some photos of the 'middle' position
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
Only two positions, locked and unlocked, "neutral" is meaningless and the bloke in the video doesn't seem to know his arse from his elbow!
If you take it apart you'll see how simple the mechanism is and how absurd the idea of neutral on a diff is ![]() |
transfer box neutral for using PTO if fitted
True, but this thread is about the CDL not the t-box gear selector.
I did have a little look down the switch hole, you can see what the lever is doing, its strange the empty slot is exactly the same feel as the locked position on the ball detent, like a solid positive click
Aye the transfer box neutral works fine, as I do have and use a PTO
There are only 2 notches for the detent ball in the difflock selector shaft. I suppose it is possible you're moving the shaft further than its normal travel and feeling it pass beyond the detent.
Good enough for me! haha also, any reason there is a switch on my pto linkage? it is fed 12v and is closed when the pto is engaged. doesnt seem to light anything though, the switch was broken in closed, but now it is working again although i havent noticed any difference |
I imagine it was a warning light or possibly some kind of lock-out to prevent something from happening with the pto engaged. Hard to say without knowing what the pto was originally used for.
Used for my winch and tool take offs, doesn't seem to make any odds, I'll add it to the 'f knows' pile
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
You'd have to follow the wire from the switch to see where it goes. I think on some vans with a PTO when you engage the PTO, the idle speed increases, could have been something do with that.
