![]() | Home > Puma (Tdci) > central locking |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Today I noticed that one of the rear passenger doors (110 station wagon) was not locking when all the other doors were locked.The push button was not going down far enough.As a purely emergency measure I put some general purpose oil down behind the push button.Anyway it worked.So I did the same to the rest of them.When I am next at the dealer I will get it checked out but if this works it will save me going down specially. I have tried it a number of times and it is working o.k.Thought I would mention it incase someone else has the same problem.
Also I remember people mentioning about their handbrakes getting hot.Last week while driving in some very cold weather I noticed my handbrake lever getting hot.I just felt it while driving.I turned off the heat and it cooled down-so did I.It seems it is caused by the hot air hitting off the bear metal on the handbrake lever. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 ![]() |
this happened to my 130 last week. they fixed it quickly by taking off door panel and lubing all the movements. works a treat now. Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
RgrBox Member Since: 04 Jun 2009 Location: St-Cergue, Switzerland Posts: 111 ![]() ![]() ![]() |
MY problem is that sometimes the rear door won't un-lock.. also the damn thing is sensitive.. goes off in my pocket sometimes.. then the alarm goes off.. 2008 110 2.4 tdci csw
Landrovers of Switzerland Club member |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
I'll do you a swap, my remote is crap. I have to be so close for it to work, I might as well use the key. New batteries don't help.
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Mine too. 3 meters if i'm lucky. Did you know holding the remote fob to your temple extends its range? You then act as an aerial to the thing and you can ping you lock at 5 - 6 meters. God knows what it's doing to my brain. If i have one. |
I think I'll struggle on. Don't want the men in white coats to come knocking.
Same here.. I wish it didn't have this remote stuff sometimes...
RB 2008 110 2.4 tdci csw Landrovers of Switzerland Club member |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
As demonstrated by Clarkson on Top Gear... hold it against your head and push the button. Vastly improves the range of the plip.
Otherwise, mines like ever other one, 3 metres is about it! All the same its a lot better when running for the car in a tropical storm, to be able to unlock with a press as you approach the Defender. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Same here but 3-5 mt only in environment without any radio interference. In the city should be 1 meter, no more.
and as the others it is not sensitive at all ![]() RgrBox. maybe your remote are not working well ![]() Courious why LR has not improved the range of the remote lock or at least paid us a contorsionist course to get more range. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I can't believe we're having this conversation about the range of our remote central locking for DEFENDERS!
![]() For the record, mine is also limited in range and angle of approach. "head shot" works well and so can "shooting from the hip". I'm just chuffed I can do it remotely at all ![]() + New Defender 110 First Edition |
The range was reduced to stop undesirables from scanning your remote frequency. 2.4 90 XS
What kills me, is that the damn thing will go off in my pocket, and lock the truck while I'm trying to take something out.. but i have to bang on the damn button several times to open it when I want to open it????
RB ![]() Landrovers of Switzerland Club member |
niglyn Member Since: 12 Jun 2009 Location: Surrey Posts: 82 ![]() ![]() ![]() |
The remote having limited distance is a fault. Mine would only work when right above the engine bay, no good if you need to open the back.
The dealer was going to change the ECU (as advised by Landrover Technical) when removed they found the antenna lead had come out of it's socket, more than likely during installation. Works from a greater distance like any other car now. Unfortunatly I do not know the exact position of the ECU, I am guessing it is behind the drivers instrument cluster as thets where my fob worked best. Would like to hear if this info solves the fault on other vehicles BR, Niglyn |
The ECU is under the driver's seat. I wonder how obvious the aerial is? I haven't looked for it.
