![]() | Home > In Car Electronics > Microphone placement |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
you have a choice of 2 places one on the steering column
![]() Click image to enlarge or on top of the dash . you may just see the wire on the top right of the picture. some firms drill a hole but it will fit without usually. both of these places work reasonably well without picking up to much wind noise or fan noise |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
Fed it thru with a coat hanger, mic is mounted on the steering shroud
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
I took centre dash panel off, run mic up, refitted the dash panel and clipped it by the heater vent
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
It’s easy with the steering column plastics off My 90 Project : http://www.defender2.net/forum/topic52774.html
Iggle piggle Member Since: 10 Sep 2014 Location: Wales Posts: 378 ![]() ![]() ![]() |
I moved mine to the headlining just in front & above the drivers head, it stopped everyone shouting "what! I can't hear you"
Especially when going round corners when the steering wheel covers the microphone! |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
Mine is mounted at the top of a-post trim. Seems to work well. 2007 110 TDCi Station Wagon XS
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
I found mine was hit and miss in the above location, not sure why though, you had to make sure you spoke at it if a start.
I don't think they are the best any of them to be honest, they are far to quiet. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
You could put it where the factory put it - right in front of the side/headlamp warning light!!!!! It really does annoy me, just something else to add to the list of why I'm a grumpy old man. Defender 90XS SW
I’ve moved mine up to the a-pillar - I’ll let you know if it’s better that on the steering cowls My 90 Project : http://www.defender2.net/forum/topic52774.html
Get a mud roof console and put it on the edge of that closest to you, mine now works brilliantly
![]() My build thread http://www.defender2.net/forum/topic17615.html |
