Home > Maintenance & Modifications > 235/85 R16 on standard steel 5,5'' rims? |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
I would rather fit 235 tyres on 6.5j rims as it sits better on these.Wolf rims are not that pricey anyway. Puma 110 SW
90 V8 SOFT TOP |
4th Apr 2011 2:39pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Technically you can do it. If it is allowed in your area????
BUT: Do not mount tubeless tyres with tube! WANTED: SII or SIII in max 1.5k |
4th Apr 2011 3:12pm |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 |
Ive got 235 85 r16 BF Goodrich Mud Terrains fitted to standard steel rims, which my local dealer fitted for me when I purchased my 90, and have had no problems with them at all.
4th Apr 2011 7:33pm |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 |
I fitted 235-85-16 on my standard steel 5.5 rims 10k ago. No problems at all.I have seen plenty of these through our workshop,all fine. Its never over in my land rover.
2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
4th Apr 2011 8:29pm |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 |
Thanx everybody for your replies.
So I will go for it and send photos just to have a reference on how they fit. I am between BFG Muds and XZLs. Can't decide yet... |
5th Apr 2011 6:22am |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
http://www.tetrakinisimag.gr/tyres_&_sizes.htm
it is up to you mike www.newfoundland.gr |
5th Apr 2011 7:59am |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793 |
Min 6J rim for 235 section recomended.
Andy. |
6th Apr 2011 12:00pm |
mike, a month ago ''kabletsas'' had 5 used but in exellent condition wolf rims.
try a call there andy, that's the proposal ............ www.newfoundland.gr |
6th Apr 2011 1:14pm |
I have plenty tube type WOLF rims, all new take off's in white.
Andy. |
6th Apr 2011 2:10pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
andy,
do those wolf rims fit a normal 110? i remember reading that certain land rovers needed longer wheel studs before they could be used? cheers |
7th Apr 2011 7:47am |
You can't quite get a full nut on the stud, if anyone is worried we fit dome'd nuts, but it's still the same but you can't see it, if you know what I mean.
Enough to hold the wheels on though. Andy. |
7th Apr 2011 7:53am |
cheers andy
i take it that only 130s and mod landys have the longer studs as standard? |
7th Apr 2011 7:58am |
I don't know for sure, will have to check that one out. Andy.
www.ajstyres.co.uk 01737 241370 Junction 8 M25 Surrey. |
7th Apr 2011 9:46am |
Thanx for the info Andy, but please explain a bit the "tube type" thing... Is there a difference between tubed and tubeless rims? Can I fit tubeless tyres on the tubed rims? What type (tubeless or tubed) of tyre is better for 70% off-road and 30% hard off-road use in mud and snow. Sorry but I am new to these issues Mike. |
7th Apr 2011 9:49am |
