![]() | Home > Maintenance & Modifications > Wiring route to Heated Windscreen |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Would someone with a 2 tab type heated windscreen (preferably factory fitted) mind looking at where the wires are routed to the screen and how they are terminated to the screen please.
I am just putting the wiring into my replacement wiring loom and unsure what length/route they take to the screen. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Spade connectors (can't remember the size but I think 6mm), one in each lower corner.
cheers, I presume the wires follow the same route as the loom running up the A-Pillar does on the RHS?
Which orientation are the terminals, cant quite make it out on the photos online from VGS Steve 02' 110 TD5 Double Cab Rebuild Thread |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 861 ![]() ![]() ![]() |
The wiring doesn't get as far as the A pillar, it just comes out between the top of the dash and the screen rubber
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
6.35mm Posi-Lock are the original fit, they latch onto the screen tabs.
