Home > Technical > Electric Window fault
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Hi.... Just a quickie.
Our 02 Defender's just developed a fault on the OSF electric window.
Definitely not the fuse, switch or the motor at fault..... any ideas welcome
cheers
Post #252798 21st Jul 2013 4:54pm
GUM97
Any more info than "a fault"? That's a bit vague! Laughing An engine to TDi for!
Post #252799 21st Jul 2013 4:55pm
mk1collector
Probably a snapped wire in the rubber boot between the door and post
Post #252801 21st Jul 2013 5:05pm
under_rover
Won't go up or down....I've put a separate supply on motor which worked, swapped fuse and swapped switches over with each other.
So I suspect either a break in the loom or could there be another connection somewhere that may have come adrift?
Post #252802 21st Jul 2013 5:06pm
Almost certainly a break in the wires leading to the door as mentioned above. It's a common fault. Darren
Post #252807 21st Jul 2013 5:21pm
under_rover
Yep.... that was it.... a broken red wire in the rubber boot....cheers for your assistance Very Happy
Post #252828 21st Jul 2013 6:39pm
keith
Drivers window stopped today .
Forget using the solder iron as the solder won’t take to the cheep LR wiring of the loom .
Managed to make the incision in the exact right place and guess what I found ?
Notice the blue also on the way out so both repaired with extended length of new wire.
Post #664394 14th Nov 2017 10:43pm
mk1collector
It must be the cold weather as my central locking stopped working on my drivers door last night but worked again this morning Rolling Eyes Ray
My build thread
Post #664405 14th Nov 2017 11:18pm
keith
Cold weather Shocked never stopped a Landrover
It’s positively balmy up here and I got eaten by midges whilst changing out the wires .
Laughing
Keith
Post #664406 14th Nov 2017 11:22pm
mk1collector
Cold weather stops mine, I'm sure it's snow shy as its broken down twice the week the snow started Rolling with laughter and it must be getting nervous now we've had a couple of frosty mornings hence the broken locking Rolling with laughter Ray
My build thread
Post #664407 14th Nov 2017 11:25pm
under_rover
I'm glad it was an excellent summer when mine went pear shaped, had to drive all the way home from Scotland with the window fully down Rolling Eyes
Post #664423 15th Nov 2017 9:11am
