![]() | Home > For Sale & Wanted > BAS IID Tool with 170 BHP Remap and 2.2 Puma ECU - NFS |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3413 ![]() ![]() |
I believe the remapped ecu is paired to the original chassis number meaning it can't just be transferred? Probably worth checking with BAS
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501 ![]() ![]() ![]() |
Interested but not sure how this would work. 1951 80" S1 2.0
Knoxy Member Since: 06 May 2013 Location: The Moon Posts: 43 ![]() ![]() |
Thanks I have a query into BAS to clarify.
My thinking is that because the map is loaded to the dedicated ECU supplied by BAS and the IIDTool is paired to that ECU that it would work but I’ll defer to BAS’s guidance on this.
The ECU is very easy to change, only 3 plugs and a couple of bolts and you can swap ECUs without any issues. |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 852 ![]() ![]() ![]() |
Just for info and not wanting to upset anyone but...
The map and ECU will not work on a different car as it is VIN coded to the original vehicle and contains the injector codes etc etc for that vehicle. For someone to use the BAS2 RRC tool (not IID as stated) it will require a new registration and re-map and this will cost £350 + VAT from Pete. The 2nd ECU is slightly redundant now in that the process has moved on and is now full OBD without the need to split the ECU so unless someone wishes to have a second ECU that they can put on/take off for some reason it is not required. So effectively you only have the secondhand BAS2 RRC for sale without a re-map and new the tool costs £250 + VAT from Pete without a re-map so maybe you need to revisit the pricing - sorry to be the bearer of bad news but on the plus side you have enjoyed the re-map for a couple of years ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Thanks for your input.
This correlates with the info I got from Pete. As such I’ll throw the bits in the back of the shed as its probably not worth the hassle to sell the tool only. I agree, I did have the benefit of a truly fantastic upgrade..........for a while but I have previously and successfully used “Original Tuning Box” at Spa in Belgium to tune my Diesel cars, which retain some aftermarket value if you change the car. Whilst I cannot fault the BAS solution, in hindsight the external box solution would appear to be a more prudent aproach. However, at the time of purchase I did not intend to sell my Defender so happily paid £840 for the best solution but thanks to crapy service from the Main Dealer and JLR, as they say on Dragon’s Den; “I am out”. I wont loose any sleep over it. |
From what I read on here the second hand BAS2 RRC are fetching about £150 which is not bad when added to a reduced price for a re-map from Pete at £350 + VAT (usually £495 + VAT but reduced by Pete to help the second hand market for the tool) so you could sell it fairly easily?
Or depending on what you do in the future you may (please don't bit my head off) purchase another Defender sometime ![]() ![]() Also, up until the BAS2 RRC came along just over 2 years ago the only way to tune a Defender was to split the ECU and use the original when taking it back to LR for any work it needed which meant swapping ECU's each time and was a bit of a pain. The tool allowed you to take the re-map off/put it on within 2 mins or so at anytime using the split ECU. Now the ECU can be re-mapped via the OBD port which is only natural progression I guess ![]() Did your Defender go back to LR ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Duplicate Post
Duplicate Post
Hi Thanks for the info.
Ill give it some thought. I cant see me buying another Defender as my own was my perfect spec. You can never say never though. I’ll just have to make do with the Cayenne. I wont risk the wrath of the faithful by suggesting that unless you are seriously offroading most of the time, its a vastly superior machine in every measurable way. Not sure I got a free ECU as I paid £840 for the kit I purchased which comprised the Maps, the tool and the ECU to allow stealthy swap out for warranty work and BAS excelent support of course. My wallet at the time did not feel like it included a free anything let alone a free ECU? I would like to say though that in 10K miles, with the remap fitted from new (at 500 miles), the car performed faultlessly. Not a trace of soot in the exhaust, not a whif of smoke, easier to drive smoothly and when removed the car felt as though the handbrake was stuck on. If you are thinking about a BAS remap Just Do It. |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2703 ![]() ![]() |
Why not locate the new owner of your Defender and offer it to them? 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
So you have 3 Porsches in your garage but when the Defender was off the road for 2 days you were stuffed because Land Rover couldn't provide you with a courtesy car. Therefore: 1 Defender = >3 Porsches... |
My wife runs the Cayenne, the 912 is concours and the value has jumped higher than long tailed cat in a room full of rocking chairs and I dont run the Cayman in
![]() By comparison, the Cayenne was bought from the Official Porsche Centre in Glasgow at 3 years old. 2 weeks after purchase we called into the dealer unannounced on a Saturday morning and mentioned that there was a bit of wind noise from the drivers door. They put my wife in a new Macan courtesy car there and then and kept her car until it was repaired 3 days later when they delivered the car the 35 miles back to her. If your happy to think that a Defender = 3 Porsches, Im happy to let you. ![]() Last edited by Knoxy on 15th Nov 2017 6:36pm. Edited 1 time in total |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
![]() ![]() Cheers alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
