![]() | Home > Td5 > Repair fork 576138 |
JediG Member Since: 09 Jan 2016 Location: Omsk city from Siberia Posts: 3 ![]() ![]() ![]() |
Hello!
![]() Click image to enlarge Has anyone done the recovery of the clutch fork 576138 engine TD5? The plug is in perfect condition. I would not want to buy a new fork. For some reason, Land Rover did not foresee the replacement of rod insert. I would like to find a suitable budget solution for the restoration of this part. Maybe someone has already done this? Last edited by JediG on 14th Nov 2017 8:34pm. Edited 3 times in total |
What bearing do you recommend to use?
Loctite 641 - Medium Strength Bearing Fit Retainer 10ml
Where can I get a rod insert? The one that was broken.
