Home > Puma (Tdci) > TDCi Mpg's
Page 9 of 13 <123 ... 8910 111213>
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Update on mine (@ 7500 miles):
A tank full of short trips on minor roads with mixed loads still yields 29 to 30mpg.
I expected motorway driving to at least equal (or better this) as I get more use out of 6th gear, but several long drives to the Lakes and back (needle showing steady between 70 & 75mph) average 26 to 27mpg.
(The opposite to my previous V8 which used to be several mpg better on motorways than minor roads).
I feel it's worth knowing what it typically achieves so if it ever drops off I'll know something is wrong.
Also zeroing the odometer every fill is a useful guide to range - I know there is 300 miles in the tank.
Post #6291 14th Jan 2009 12:49pm
spudfan
Ireland
Last fill up returned 25.8 mpg.Family car so lots of local small trips mixed in with the longer stuff.Best ever was 29.7 on a long journey. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #6323 15th Jan 2009 9:10pm
Caterham
I'll have a look tomorrow but this tank saw one trip of circa 200miles and the rest just local ie less than 10 miles and at the moment I know its very nearly 370 miles and the low level light hasn't yet come on.
Post #6375 17th Jan 2009 10:12pm
Caterham
well 400.7 miles before filling up again.
thats about 26.5 mpg Sad
what did I expect. its just a bit hard when the last car did <73 mpg on a tank (<60mpg on home made bio)
Post #6614 26th Jan 2009 10:17pm
SFDM
England 1999 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Just filled up.....25.6mpg Ne nostra in fundamenta subeamus
Post #6638 27th Jan 2009 11:40pm
Femund
Norway 2008 Defender 110 Puma 2.4 XS CSW Java Black
And the last car You had was comparable to the Defender (like; permanent 4WD, air drag like a brick, weight about 2 tonnes....)?
Then I agree with You in this one Crying or Very sad
But if Your last car was a Smart or a Toxxxa Aygo, then............ 08MY Defender 2.4 SE
Post #6640 28th Jan 2009 8:48am
Caterham
well it had 4 wheels Very Happy
a citreon picasso - was really making a comparison as much as to say it was a bit of a culture shock.
Post #6648 28th Jan 2009 2:24pm
mse
im shocked...it has to be a record 35.7mpg!!! 386miles with 49.06l required Mr. Green Mr. Green Thumbs Up Mike
Post #7075 10th Feb 2009 12:17am
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Still keeping track of mine - average 28.4 over the first 5,000 miles, which disappointingly is slightly down on the old Td5.
As mentioned elsewhere in this thread, strange for a vehicle with cleaner emissions AND a small claimed reduction in CO2/mile. What's also odd is that I get just over 30 on local/short trips, but drops to 25-27 on motorways, in spite of the 6th gear (generally around 70mph). The Td5 didn't suffer that way...maybe the non-perforated sump guard acted as an up-side-down aerofoil and cleaned the airflow under the chassis??? It seems a bit far-fetched... 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #7102 10th Feb 2009 5:03pm
gtveloce65
Mike - meant to say - 35+ mpg??? Shocked Yours is a 110, isn't it? 1953 80
2008 110xs
Post #7103 10th Feb 2009 5:05pm
gtveloce65
ah no - I must learn to read things properly!!! I should probably be happy with 28/29 out of a 110 1953 80
2008 110xs
Post #7105 10th Feb 2009 5:07pm
mse
no its a 90 Mike
Post #7106 10th Feb 2009 5:07pm
gtveloce65
Yes - realised my mistake as I pressed submit... Embarassed 1953 80
2008 110xs
Post #7108 10th Feb 2009 5:14pm
mse
No problem - if it helps the disco only did 29 - usually does 31 Mike
Post #7110 10th Feb 2009 5:22pm
Caterham
406 this time and the warning light came on. filled up at 420 which is about 28mpg.
Post #7322 15th Feb 2009 10:39pm
