Home > V8 > 90 V8 ragtop value? |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1031 |
Thanks Kit
Do you have an idea of the labour cost? I’d guess that there would be some savings doing both at the same time but even at a labour rate of £50 per hour, I’m guessing the labour for a chassis / x member swap would be £5,000? So parts and labour would take the work to circa £9-10,000? |
12th Nov 2017 1:07pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
It's really one of those how long is a piece of string items, the problem is, if a chassis needs replacing there's a good chance that it's going to be a tough job with broken/seized bolts and replacing/repairing other items while it's in bits. The bare minimum would be a weeks work though i'd say, you'd probably get a discounted rate on the labor since it's a big job, i'd factor (depending where you are in the world and who you use) 60 hours (two guys) at £35 an hour - £2.1K. The rear cross member is a part of the chassis, so you would do one or the other, it just so happens to be probably the worst designed part of it! 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
12th Nov 2017 1:49pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1613 |
A new galvanised chassis from Richards is less than half that. Typically around £1500 for a 88in Series and a bit more for a 90. |
12th Nov 2017 3:47pm |
double post 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top Last edited by Kit on 12th Nov 2017 4:23pm. Edited 1 time in total |
12th Nov 2017 4:15pm |
My quote inlcuded items that needed replacing during the chassis change, the bare chassis price at the time was £2400inc VAT, I don't know who the manufacturer was though 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
12th Nov 2017 4:23pm |
