Home > Maintenance & Modifications > Hard Top Roof Ribs
Blakey007
United Kingdom 2000 Defender 90 Td5 CSW Coniston Green
Hard Top Roof Ribs
I have an early Defender Hard Top with the external Ribs, is there someone on here that can point me in the right direction to source replacement ribs? The roof is near perfect condition except one of the strengthening ribs.
And is there a master list of seals required when removing/refitting the Hard Top? I have a kit of new bolts/fixings just want to be sure I have all the necessary rubber seals before removing my Hard Top to repair. Very Happy
Post #661985 5th Nov 2017 3:25pm
ibexman
I’ve never seen them sold separately but could be wrong
Post #661994 5th Nov 2017 4:32pm
Blakey007
thank you for the reply ibexman, maybe i should purchase another Hard Top but it does seem excessive just for a Rib, unless anybody on here knows of a roof kicking around that they can remove a Rib from? only need the front tapered section about 30 cms long.
Post #663495 11th Nov 2017 6:47pm
grafty99
Could it be repaired? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #663500 11th Nov 2017 7:00pm
Blakey007
yes the roof can be repaired with the new section, my front section of Rib was caught under a low branch and peeled it off the roof, I have tried to make it the correct shape but panel beating skills are poor, hence the request for a replacement Rib I can pop rivet into place
Post #663515 11th Nov 2017 7:43pm
Mo Murphy
You could try YRM, see if they'll make you one.
50 Shades of Pennine Grey
Post #663521 11th Nov 2017 7:58pm
Blakey007
Thank you Mo, I have emailed them and will post their response on this thread
Post #663529 11th Nov 2017 8:09pm
Some skilled guy with a folding/brake press may be able to make good of your part or be able to bend you a length up?
But I think another roof may be easier QRZ 2e0vpf
Post #663534 11th Nov 2017 8:19pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I have a ribbed roof in my garden that I was just saving for the holes (template to cut vent holes in existing roof to add tropical roof).
I'll have a look and see how easy it would be to remove a rib.
Post #663551 11th Nov 2017 9:19pm
Blakey007
Thank you Inigo, that would be great Very Happy Very Happy
Post #663699 12th Nov 2017 2:20pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
Blakey007,
I've just done this repair to my ninety's roof and have one spare rib left Shocked
I bought a roof that had a damaged corner but the ribs were OK. I used a spot weld drill to drill the damaged rib to free it from the roof and then drilled the damaged roof to free the rib, thus ending up with a good rib with no holes and a good roof with a missing rib and no holes.
The good rib was then fitted to the roof but the dome head rivets at the cab end didn't line up with the existing holes, so a bit of ally plate had to go inside the screen frame mounting pressing for the rivets to pull against. Had to drill some 1" holes to access the pressing though. Rib and roof were drilled and countersunk for 5mm closed end rivets at 60mm centres, cleaned and primed internally with epoxy etch primer before bonding and riveting in place with sikaflex 252.
As far as making a new rib with a press brake, the problem is that the ends have a curved taper on both ends and a drain groove at the front end, so would need to be die pressed rather than folded to look in-keeping with the remaining ribs, hence why I recovered good ribs from a damaged roof.
You are welcome to the rib I have if its any use and if Cornwall isn't too far to collect it.
Paul
Post #665132 17th Nov 2017 6:21pm
Blakey007
Good morning Horneteer
That is exactly what I need, I do travel to Cornwall a few times a year but will be unable to do that before the New Year Sad
Is it possible to post it too me? I will obviously cover all costs incurred Very Happy
Please PM me to discuss the finer details Thumbs Up
Post #665268 18th Nov 2017 12:09pm
Horneteer
Pm sent
Post #665282 18th Nov 2017 1:34pm
