![]() | Home > Maintenance & Modifications > MUD DEFENDER ROOF CONSOLE |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
dysfunctional pigeon
Hence the (may) mine is tight to the rubber , the fitter might have been very cautious I needed to tidy the GPS & BlackVue wires any how
I'd rather the fitter ask than damage anything |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
Sorry, Ken, I didn't mean to sound argumentative! I was trying to reinforce your "may" but probably chose my words poorly.
No Offence taken at all
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 825
Nice! Curious about the grab handle, can it take the full weight of a person? Will it hamper ingress and egress? Where is it attached to? Where'd you get it? |
| myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153
yes - it is bolted through to plate I attached to the inside lip [behind trim]. The handle was amongst my pile of old parts - Rover I think. No, it doesnt hamper access....
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087
Sorry to drag up another old thread, but it seemd logical, rather than starting another, as just caught up on this one after having been looking at the MudStuff Console, which unfortunately did not come back in stock, coincidentally, until their recent discount finished...
After reading all the recommendations here, I have just ordered the new Black version for Ven's Keswick Special... Hopefully fitting will be a doddle for this numpty, although I am seriously tempted to have it done by the professionals, while they still have the Special in build... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
| sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96
I was just wondering if i can fit the Mud roof console if i dont have a headlining on my 90 hardtop in the first place......would it fit anyway? appreciate your experiences
thanx Happy Travel www.thegippo.wordpress.com |
| Bug Member Since: 03 Mar 2016 Location: Hayling Island Posts: 20
I know the rear washer pipework and some wiring runs above the doors - near side or both? Does anybody have any advice for drilling the door frame and fitting the self tappers without risking damage to pipe/wiring? Hoping to fit mine sometime next eek.
| Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315
The wires and rear wash pipe can be lifted away so the drill bit doesn't interfere with them.
May be worth using a bit of tape to hold them out of the way if you are doing the job solo! Sandy |
The joys of a 64 plate 110XS, I was hoping not to have remove some of the internal trim and open up the side of the headlining for access.
| chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264
Maybe the first stage of the fitting instructions (fir tree removal) is to clear away the pipes and wires?
Thinking of getting one of these........is it easy to run extra wiring to the console? Can interior light circuit take any heavier loading? Just for phone/ipod charging. |
Moving the headlining to tape the wires and pipes out of the way was easy and fitting was straightforward, even without any help.
I didn't plumb in any extra electrics and not sure how much load you could put on the interior lamp cct as, although it's on a 10A fuse with lots of other stuff, the cabling is quite small. |
| Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 411
Hi Craig, Do you have a picture of the CM10 fitted? I am thinking of buying the MUD roof console to fit a Midland Alan 48 Pro that is W154 x H50 x D175 I am happy to cut the headlining but I wonder at what point the back of the unit will actually touch the skin of the roof? Cheers Yan |
| All times are GMT |
