Home > Td5 > Turbo questions tuning
Welkman
Hi all,
Does anyone know what the maximum boost a standard td5 turbo could theoretically generate without overspooling? Im playing around with my stage three tuned td5 and have had a couple of incidents where the turbo cuts dramatically on full load. This has been at around 1.75 bar. I think it could be the intake pipe collapsing as it does not trigger engine protection limp mode.
Any ideas what othe tuned td5s are running?
Thanks
James
Post #663211 10th Nov 2017 7:59pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
mine runs happily at 20 psi at the minute, ive had 21 to 22 but that's about 1.5b 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #663224 10th Nov 2017 8:43pm
grafty99
It could be the maf sensor tripping out. This doesn't bring on the engine management light but does cut the power. One way of stopping it is a dual channel limit box. Much over 20 psi and the standard turbo becomes inefficient Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #663303 10th Nov 2017 11:41pm
jst
we used to run 25psi on Allisport tune Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #663363 11th Nov 2017 9:49am
Welkman
Thanks for the comments guys. It is analive turbo with the billet wheel etc. As of this morning it seems to be happy at 1.7 bar which is just over 24psi. I just want to work out the thoretical limit of boost on this turbo so I do not damage the thing. It also has an uprated map sensor so should cope.
Post #663396 11th Nov 2017 11:45am
bankz5152
Boost is too high.
The standard turbo will put out 30psi max but ideally set at 18psi anymore and you get lag, even with an uprated MAP+raised boost limit or boost box. If you are running higher boost i suggest you use a boost controller/bleed vlave to properly control the boost as the standard (even forge) actuator is not up to the job of much past 20psi.
MAFs are hit n miss, including genuine ones some will run gladly at 24psi some wont
Edit
Just saw youve an alive turbo. Is it Hybrid or VNT? Either way 22 - 24psi is the sweet spot any more and lag.
Post #663442 11th Nov 2017 2:01pm
Welkman
Hi again,
It is the hybrid turbo. Seems smooth at 1.7 bar but will knock it down a bit and see how it performs.
Post #663460 11th Nov 2017 3:31pm
bankz5152
Still a touch too high. 22 is optimal for a hybrid,as I said best to use bleed valve or boost controller. Other wise you end up with "boost creep" which is not good!
Post #663462 11th Nov 2017 3:44pm
Welkman
Thanks for that - could you explain the bleed valve or boost controller so I can understand how they work alongside the current setup?
Post #663466 11th Nov 2017 4:19pm
bankz5152
Basically its a little valve that sits in between the actuator and pipe, it bleeds off excess air so you get the correct boost.
Set the actuator to standard then adjust the boost controller up or down till you hit 22psi which is ideal for a TD5 hybrid, any more and it lags.
More boost doest always mean more power/better running.
Post #663726 12th Nov 2017 4:41pm
