Home > V8 > Defender/Disco v8 4.0 - centre console.
jackdefender1991
United Kingdom 1991 Defender 110 200 Tdi DCPU Aintree Green
Hello all,
I am about to start fitting my v8 4.0 auto into my 200tdi defender.
I have seen the contre console from a v8 disco on eBay and wonder if it will fit once the v8 is installed into my defemder?
The NAS defender centre console is very expensive to buy, has anyone ever fitted the disco centre console or made their own?msee the attached photo
Any help appreciated, cheers
Post #662594 8th Nov 2017 11:20am
People have converted to the disco version, assuming you're cute with tools, it's not a massive job.
As the shifter is on a cable, mine is mounted next to my handbrake for easy reach and i can still use a normal cubby box.
It seems a shame to lose a big cubby box, just to have the shifter in the middle.
Post #662610 8th Nov 2017 12:16pm
Devon-Rover
Whilst it is daylight robbery the Ashcroft '50th' style centre console looks the part and finishes it off nicely. I 'metaphorically' cried when I ordered mine but it does look right and set's the shifter nicely.
Post #662699 8th Nov 2017 7:58pm
it is robbery as well. It doesn't even have the cup holders like an NAS does....
Still nice though Cool
Post #662707 8th Nov 2017 8:32pm
JeremyJ
Not a bad thing, I always find cans fall out of them (original 50th’s and first version of Ashcrofts).
Current version takes an iPhone nicely, I like it.
If (when...) my 110 goes auto I wil probably use an Ashcroft console, I like how they look (especially in a 110! Laughing )
Post #662742 8th Nov 2017 9:57pm
Romadog
Jeremy - it looks great in mine and the one i picked up earlier in the year will look good in my 90......when I get near the point of fitting it !! Very Happy Thumbs Up
Post #662863 9th Nov 2017 6:55pm
jackdefender1991
I may actually choose the Ashcroft , they do look good
Post #663038 10th Nov 2017 11:23am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
It would probably be cheaper to have a company fabricate a metal and leather cover for it, than that Ashcroft item 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #663048 10th Nov 2017 11:47am
Albert McFly
I have a spare Ashcroft one in the garage Whistle
Post #663583 11th Nov 2017 10:45pm
voorfrank
Netherlands 2002 Defender 110 2.5 TD SW Bonatti Grey
I have used the tunnel, carpet, sound insulation from the donor disco. I cut the parts to the correct size and used silicone to fit it to the Defender. It works perfect and I think looks very original.
Post #685644 10th Feb 2018 9:11pm
Tidy job.
Post #685645 10th Feb 2018 9:15pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Lovely job.
Post #685712 11th Feb 2018 9:43am
Wheel
I like that a lot, we'll done Voorfrank
Have you any step by step pics please
Mark
Post #691780 7th Mar 2018 7:40pm
Zed
Looks great voorfrank.
Post #691784 7th Mar 2018 8:06pm
voorfrank
Yes, it looks very original.
I don't have pics of the install. I cut out the tunnel out of the discovery I used for the automatic transmission. this is a discovery 1 wiht mechanical transferbox linkage arms and not with cables. Measured the distance of the levers to get it on the original position in the tunnel and cut the tunnel down to make it fit to the bulkhead, floor and seatbox. when this was ok I also cut the discovery carpets to the right size. The discovery floor hight is the same as the defender floor hight. when everything was correct I fixed the tunnel simply with silicone all around to the defender. If needed you take a knife, cut the silicone and you can take the tunnel out again. The discovery tunnel is bigger than the defender, so I cut the floor to the tunnel dimentions.
That's all. Smile
Since I used the discovery gearbox and engine, a 3.9V8i, I also fitted the dash, under the bonnet fusebox and wiring of the disco. Most wire colors are the same on disco and defender.
Post #691886 8th Mar 2018 10:21am
