![]() | Home > Tdi > 200Tdi Race engine - Weak points and limitations |
| Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 235
Interested! 1990 Defender 110 200TDI Camper - now converted to Td5 power
| Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313
You may wish to grab a coffee for this…..
So the block (which is a 200tdi) was bored +40 thou oversize and decked flat All new cam, crank etc. bearings fitted New pistons, rods and crank were fitted after being balanced with the flywheel and clutch cover (some guts is 300tdi) The pistons were ceramic coated on the crown, and Teflon on the skirts A new 300tdi head was sourced, with new valves etc. then was ported Head is fitted using ARP studs Modified injectors Internally modified fuel pump VNT turbo from the guys in Portugal Custom 2.75” downpipe which mates to an Alive TD5 sports system (2.5”) Currently using a BAS TD5 intercooler with custom SS pipes A bit of a Frankenstein, but ticks over sweet as a nut |
Thanks for the update, this looks like a great project (hopefully you can get some dyno figures...).
What 300tdi parts did you use other than the head gasket? Thanks! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Hopefully will get it on the dyno when complete
Pretty much a 200 bottom end and 300 top end with 300 rods and pistons. |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221
Exciting stuff!!!
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798
Yep, Dyno figures would be very interesting, incl torque. Pickles. |
| Boost Member Since: 17 Oct 2014 Location: Gloucestershire Posts: 203
Did the ARP studs fit alright in the end? This must be one of the most refined tdi's in existence now! Hopefully |
Yes. Got them all sorted and clamped down real nice
| Dorothythedefender Member Since: 29 Jun 2020 Location: scotland Posts: 1
Really like this thread and all the info. I have followed the Blue 90 progress on Club 86 and wanted to do a similar thing with my 200tdi 90. I've got a Defender engine so turbo is up to and wanted to implement the same Perkins turbo swap you have coupled with a manual boost controller. Couple of questions about the downpipe and how you made that. Did you purchase a universal 3inch flange and, bolt that up and then weld the pipe to that? |
